Now home first time since 9/18
Changed the radio back to the recently-acquired Galaxy 86v.
Found the narrow-width rack to make the install.
Power lines close by here at home. Literal feet away from parking spot so engine-off is almost always 5-S.
Hooked up a trusty RK56.
Went thru the tuner to first examine and second do some TLC as one control had gotten loose. Wondered if there was light bulb to change, (no), so time to see if In the rats nest the meter power cable pulled apart.
Tomorrow time to find some RF Bond points and just have it under cabin to frame.
