Finally had some decent weather so I could climb up and change out my feed line and make a new choke. I'm only running about 50' or so and decided to use Times Microwave LMR-240. So, I installed the choke about 1 foot from the SO-239 on the antenna and then used little stand-offs to keep the coax away from the mast and tower all the way down. Buried about 6' of it between the house and the shed (where the antenna lives).
I also made new random jumpers between the radio and amp, amp and meter, meter and low pass filter. I could not believe what I was seeing when I started checking the SWR.
I set it up to be lowest at 27.355 because I use mostly the upper freqs, and quite often up to 27.575 and even 27.705. Well, I didn't check to see how far I could go and stay below 1.5, but at 26.965 I am 1.4:1, 27.355 thru 27.395 flat, and all the way up to 27.705 is still at 1.3:1. I should have made a video of this, and I still may later on. I can't believe the difference from a generic RG-8x to the LMR-240. This is incredible. Plus, I'm using an ancient Johnson low pass filter with the match adjustments in the ends, so I COULD use it as a tuner if necessary.
