What amp?
Rickryder
Mar 15, 2021
29
29
13
66
I’m considering buying an amp for my base station. I’m looking at the Texas Star dx 500v and the RM Italy kl 703 I can’t decide the Texas with DEI or HG transistors or go with a mosfit amp like the RM
Any input is appreciated!
If you have a guy that will build me a 500 watt amp for $450 hook me up!
I know there's a lot of TS bashing on the boards these days, so I'm just going to tell of my experience with no slant. I ran an RM Italy a few years back. I thought it was doing well until one day it quit. opened it up and found the fuse holder barely soldered and melted off. Also, was extremely sensitive to input power. Fixed and tossed it on the shelf. Bought a TS DX-500HDV from Delta Electronics. $460.00 with tax. My radio is too hot to run the amp on AM so my experience is totally based on SSB. Out of the box it worked fine with 30 pep watts in I was getting about 450 to 470 out, drawing about 61A, and my audio reports were very good. I did the power wire upgrade, removing the fuses and using silicone 10ga wire to power EACH board separately. So now there are 4 10ga wires protruding terminated via Anderson power pole. Now, with the same input of 30 pep watts, I am getting 650+ easily, audio reports are tremendous, and my current draw is just over 42A. PLUS, my idle voltage is 14.2 and used to drop to 13.8 while pulling, now drops to 14.1 to 14.0. Despite all the hate for these little boxes, I believe I made the right choice. AND, my input tune is absolutely perfect. Doesn't even move the meter. I may have been lucky and received a unicorn, but I don't think so. Delta tells me they are having a hard time keeping up with these. And, they come out of the box ready to go.
I’ll be driving it with a galaxy dx2547 that dead keys 2 watts and swings 25 I think that should be ok not to blow it up! It seems the kl703 needs more amps then the TS.... lm still on the fence....
Yes that is in my budget. Didn’t see that one thank you.
Okay here are pictures of the Texas Star DX500, RM Italy KL-503hd, RM Italy KL-703 and the CarlBuilt 400hd. Disregard the connectors that what’s I put on. Also disregard the word SLINGSHOT on the top of the CarlBuilt 400hd.
The Texas Star DX500 and KL-703 put out roughly the same wattage 450 give or take. That is not over driving them and using a Cobra 29 LTD Classic with about 4.5 watts dead key and 24 watts PEP. The KL-503hd does right at 300 watts as advertised. The CarlBuilt will exceed 600 watts output and is capable of being driven harder.
I don’t drive any of my amplifiers hard that goes for my Acom 2000P and Ameritron AL-82 both on 240 voltage and both exceeding 1500 KW.
I think the Pre-amp if that is something that interest you is superior on the RM Italy amps. If you’re looking for better tuned inputs (radio to amp) the RM Italy or the CarlBuilt are superior to Texas Star.
If you want to drive the amp hard both the RM Italy take up to a 30 watt input and they are more forgiving of a higher than 1.5 SWR on your antenna.
The CarlBuilt can easily take a 100 watt input. I don’t think it is as forgiving with high SWR
Inside the amps the Texas Star and RM Italy use a more finished circuit board. A few connections in the CarlBuilt are point to point soldering....meaning wires twisted together and then soldered.
Which do I like the best....my Acom 2000P, AL-1500 and AL-82 which are connected to my 10K Colossal 5/8 ground plane. The other antenna is a Sirio GainMaster 5/8 wave vertical dipole which I don’t push pass 450 watts.
Which amp will last longer between Texas Star and RM Italy I give the nod to RM Italy lasting longer. I think the CarlBuilt would outlast them both. The RM Italy does have reverse polarity protection and I think is ascetically more pleasing. Note how large the RM Italy 703 is compared to the others.
In my opinion amplifier failures are generally user error....SWR issues, driving to hard, over volting, under volting, improper connections be they electrical or coaxial.
If the amp doesn’t come with a fan for cooling...plan on adding one. The CarlBuilt comes with a fan.
