Fly away little Angel, nothing around here to get into...If you heard a bell in the distance, your little angel got her wings: now she speaks straight to Heaven. Care in what said — and how — is paramount henceforth.
I beleive the Amber light may be for the weather board??? I thought when you turn the weather frequency's on, you get the Amber light, I could be wrong,,,
Hey,THANK YOU BUD, for the help,,I had a bad D20, ( replaced )and no juice at R103,,So I replace R103, R104,( Right next to 103 ), and replaced R51, next to the Transformer, I call this the KIT, when I get a bad R103 or 104,I replace all 3 or the higher voltage parts.Butt now,,I don't have a Red light now,,Green is bright as can be, ( no more pee yellow light ), so I shall get the schematics out and poke around. You know your stuff, want to be my friend,,,I am ever ones friend. If you get the awnser before I fix the red light, go ahead and let me know, post it. But I am going to seeif I can fix it before you post, Talk soon,,THANK YOU again, fart smeller,,,no smart feller,LOLGood observation!
Not on all radios, Cobra 18 it does, but not all 25's nor the 29's - it would be nice to have a more distinct color to help identify what the radio is receiving - but NOAA blaring out the of speaker tends to remove all doubt on radios so equipped.
To help, RX light is thru the power supply - R103 a 200 ohm 1 watt resistor, and R113 - a 470 ohm resistor - supply the Green side of the Bi-color led - it's power.
How does it turn off?
Look for D20 - find it? On it's banded side, check for continuity to PIN 3 of your Microphone Jack - in RX mode Pin 1 and 4 are shorted at the Microphone. You hear the speaker thru the connection.
When you key the mike, Pin 4 OPENS, and Pin 3 SHORTS to Pin 1 - now the Pin 3 grounds the TX thru Pin 1 - turning on the TX side, and D20 - "dumps" all the power going to the Green side of the Bi-color LED - to ground - no power Green Off, when you have TX. - The Red side of the BiColor LED is on powered by the TX switch turned on by Pin 3 - so the radio transmits (if the PLL says' it's ok to do so...)
Although not impossible, the "Green" side of the Bi Color LED can go out (burn out - blow open) due to a power surge or wired backwards sort of connection to the power plug - the reverse voltage can blow out that LED's side that it was connected to - this includes if ever mic connector Pin 3 if the power was hooked up backwards and the mike was keyed - fry that little chip in a blink of an eye. Does not always affect RED - it usually survives because it wasn't in the surge path.
So if you can verify voltage going to it, thru R113 (verify R113 is not open - ohmic 470 ohms across the resistor here)
- - and if the line to the LED is near zero in voltage - then the green diode side of the LED is shorted out and that means the whole LED is replaced)
- If R113 shows about 1.7 volts - and it still won't light, it's (LED) probably bad (Green Chip blown open) and should be replaced.
I found the issue with the green light, the wire broke off the bulb,,everything was good,power through the wire,, ( OH, THIS IS ANOTHER RADIO,ANOTHER 29 LTD),soldered the wire back on the broken part off the bulb and now I have GREEN,,,Thanks again,,73's KB9GTB,,MarkGood observation!
To help, RX light is thru the power supply - R103 a 200 ohm 1 w,att resistor, and R113 - a 470 ohm resistor - supply the Green side of the Bi-color led - it's power.
Great! It doesn't take much to break the leads on those LED's, especially if they were soldered poorly in the first place. I heat shrink over each each lead and I often use a dab of hot glue or a cable tie on the wires afterwards to help reduce that stress.I found the issue with the green light, the wire broke off the bulb,,everything was good,power through the wire,, ( OH, THIS IS ANOTHER RADIO,ANOTHER 29 LTD),soldered the wire back on the broken part off the bulb and now I have GREEN,,,Thanks again,,73's KB9GTB,,Mark
