If it's not transmit, only receive, how do you know it's "100 yards" - by S meter reading or by Volume heard?
One is the Audio Chip and associated, (PA work?) the other deals with RX and AGC - if the radio is still OEM and never been touched, well - it will need to be and thru expressively confidential documents (A.K.A) Repair order - the radio will have to undergo surgery and replace several (
hundred it seems
) electrolytic caps - all due to age and inability to filter out noise and provide pure DC. They all act like resistors and load down the circuits they're supposed to filter out noise for.
You would also experience dimming effects and higher "idle current" problems because the radio simply consumes more power thru those caps acting more like lazy resistors than doing their jobs and taking out the noise.
@Rogerbird1 - as others have suggested - is the one to really talk to about this.
Head here (Read) if you need more research...
http://cbtricks.com/radios/uniden/hr_2510/
I'll also post this here to help others understand a quirky issue about Capacitors as they age,
they simply take in more power.
Whether to boot, use, or even turning off - the suck all the power in the power supply filter caps into themselves.
Put a Ammeter on the power leads, you'll see why...
