Regency Range Gain 4 pin male Amphenol part #
Champo
230
34
44
Oregon
Does anyone happen to know Amphenol's part number for the 4 Pin male mic connector that was used on the Regency Range Gain? Thanks!
Yeah that is what is so confusing. I was thinking that it is actually this one.
https://www.ebay.com/itm/AMPHENOL-9...2349624.m46890.l49286&mkrid=711-127632-2357-0
$50 is a big gamble though to be wrong. That's more than I paid for the radio. Here are some pics from my radio connector and the Ebay listing. I also threw in a few pics of the radio. I appreciate your reply.
Champo,
Here are a few pictures of the Mike plug on my Range Gain. Hope these help.
David
Reactions: tecnicoloco
DMAS,
Thank you for the pictures. They were helpful in identifying the correct connector. The two we mentioned above are sold by the same seller on eBay and the seller confirmed that the correct plug is the 91-MC4M and not the 91-MN4M. Apparently the difference is the alignment of pin 1 and where the shell is drilled. Regrettably it's the $50 one lol!
Some years ago I got talked into rehabbing a Courier Royale 23-channel base. Had that fat socket on the front. We discovered that the "front load" style 4-pin mike socket would slide right down into the outer body of the plug. The black plastic insulator is held in place with a single flat-head screw, and just gets removed to make room for the new socket.
The more-familiar "back load" style of the 4-pin 'Cobra' style socket has the nut on the outside. This one loads from the front, and has a round flange on the outside, with the nut on the inside of the mount surface.
Had some pics on ImageShack, but they have disappeared. I'll see if they survived the last 15 or so years at the shop and post what I can find later. Simply pressing the new 4-pin socket into the old housing is not the whole job. We scrubbed the metal surfaces and filled in JB-Weld on the rear of the thing, putting a sleeve around the four pins to keep the schmoo off of them. I don't know how often he uses the radios we used this trick to convert, but the modified mike socket hasn't failed in any of them yet.
Just made more sense that making an adapter cable.
