Had a puzzling issue with a SBE Console VI (six) radio. Made me suspect that the custom "brain" chip from 1979 that runs the channel display/selection had failed. Would be bad juju, since that part hasn't been made in four decades. But it spontaneously began to work before quitting again.
This radio got a full re-cap, courtesy of Klondike Mike's cap kit and sixty-plus solder joints.
But just now my idiot light came on.
Some days the bear gets you. And sometimes it's because you f**ked up.
I replaced every cap on the main pc board, and in the power supply.
But not on the separate "Up-Down Unit" circuit board where the brain chip resides.
Hmmmm. Idiot light's getting really bright just now.
Didn't have those caps left over from the kit.
Hmmm.
Looks like maybe I should make a list and change out those caps before passing judgement on that chip.
And if it still goes nuts, I'll be back to see if anyone has insights about the wacky "tin can" PLL module and its behavior after channel expansion. Had my suspicions about the low-pass filter between the down mixer and the PLL chip's divide-by-N input.
Came up dead short on that issue when the channel selector controls went psycho. Can't much judge what the PLL is doing until you can tell it what channel to select.
Hmmm.
