Trc457 alignment problem
KneeBiter
Pep is a lie.
May 21, 2014
368
383
Virgin radio. Off freq a touch on ssb. Downloaded service manual here (thank you) manual says counter on tp6. Ch1. LSB. Adjust ct5 for 33.8526. Tp6 shows nothing. If I key mic and send tone through mic it reads 26.xxxx. what's the deal? Need advice.
Worked like a charm. Dead on. Sam's manual is a misprint. Thank you.
It's not that the SAMS is a misprint. The way they do it works well. It's that whatever you are using to touch to TP6 is pulling the signal down so the frequency counter doesn't see it. You have to either have a very sensitive frequency counter or use a not contact type probe (sniffer).
Reactions: tecnicoloco
Thanks for that info. I wonder if I put my probe through a disc cap if that would help. Either way I got it done. Now to decide if I unlock clarifier or leave it stock. Decisions Decisions.
