emoved the original antenna replace with a.k40 open coil antena in factory mount behind the sleeper. Ran a new Wilson coax and when I key up the mic in am the swr alert light comes on but the meter never shows more than 1
It's when you Modulate - you say you're using the "Factory Mount" - I have to take you at your word on this.
Why?
Well, when the SWR Riser card "sees" a really low SWR - "C5" either by cap or Resistor - doesn't have much of an Error Signal (Reflected) to amplify so the Light stays off.
A small bump of Reflected SWR - then the SWR light begins to act like an MOD (Modulation) light - because the Reflection when the Signal is modulated - is just enough to trigger that light to go on - the rest is all from that reflection bump when you change antennas.
Part of the reason this works is due to what is used
above that seam - it's fiberglass
- it's the "ultra loft" extra bunk where the Grapes,
or the Lumpers Crap - is stored.
So little to no reflection.
Nothing like firing 150W linear into the back of your cranium.
The Electronics in the Reefer (if you have one) can get errant along the trip due to the RF bleeding into the sensors - one day you may have Frozen fish, the next day a stinky mess and an empty Reefer fuel tank caused by the RF making the thing think it's not right and run all the time. Be sure to keep that in mind when you run power.
Now, to me, when people start using "Factory Mount" and Sleeper at the same time in the same sentence meaning that it where it's located - I can't help but think "Duck". One from the 13'6" clearance thwacking the whip - and the sheer ignorance at the reason why "Factory Mount" and Poorly performing, High-SWR laden issues like this come up.
It's a wonder you can even use that thing.
