Delta M2 Mic audio
Cookie55
Supporting Member
Aug 19, 2010
97
99
28
Central VA
Just got a new Delta M2 mic and noticed the audio takes about 1/2 second to start after the push to talk button has been pushed. As long as you remember to wait just a bit the mic has good audio but if you don't wait you'll loose the first few words on your transmission. Any one else noticed this issue with these mics?
Reactions: AmericanEagle575
Same on this end,other than that it's been a great sounding Mic hooked up to my Ranger 2995,Solid built I feel,jmo......
I have heard this mic over the air on a conex 3300 if there is a radio with that model number, can't remember. The guy lived about 8 miles or so from me. It sounded decent for a plug and play set up on his radio, but he had the bass turned up too high for his voice. I'm glad though they still make a desk microphone that has tone control for our radios without much modifications if any. Its too bad the cb radios are getting harder to modify for a wider audio bandwidth on transmit and receive.
