i took the dive and got it
whiteastro are the fan blowing into the tubes or are they sucking the heat out
got my fans today but trying to see which way is best and what to use to bolt them or hot glue them
They are blowing the heat out of the amp. Happy DXing
Just noticed your vents are slots and mine are round holes in a chrome top. Try it with glue first unless your holes line up with the slots.
the way they are in the pic when amp is on after and talking on it i feel the heat been push out from the sides and bottom
Reactions: FlyBoy50
Flip your fans over so the heat comes out the top. Hot air Rises and you will be hastening it along. You don't want to push the heat back into you components.
Reactions: undertaker
i found this pic are these suppressors sold separately or do
you have to make them
i know the resistors are 47ohms
