Grundig Satallit 750 power supply options
Need2Know
KK4GMU - Ocala, FL
Jan 26, 2012
144
13
28
Ocala, FL
www.muccings.blogspot.com
I understand this radio works best using the D cells rather than a wall wart that generates some hum.
I'm considering an external AGM 6-volt battery instead of the D cells for several reasons:
1) The AGM would be rechargeable.
2) The AGM would last longer between charges compared to replacing the D cells after XXX hours of use.
3) Chance of D cells damaging the radio if left awhile.
Has anyone else tried this? A fully charged 6-volt AGM battery might approach 7 volts. Would that be a problem for this radio?
Nope, full D cells normally are around 1.6 Volts new, so 4 would be 6.4 Volt, 7 volt is too close to matter.
I run my Grundig Yachtboy on a wallwart well regulated 5 volts, the radio needs 4.5 volt.
If you really don't want to tak chances take a 2 amp diode up in line thatt drops the voltage 0.6 volts.
I don't see a problem with a well regulated wallwart of 6 volts, you can add a capacitor for extra filtering if need be.
That is the way i went no humm or buzz to be heard, i took an old transformeer wallwart put in 5 volt regulator and added some extra 1500 microfarad capacitor over the output, clan as a whistle.
Well, I hooked up my 6 volt (6.31 volt) 5 amp hour AGM battery with this charger:
Was $9.95 on Amazon, but "currently not available" but there are similar cheapo units available.
No more noisy wall wart. No more D cells.
Strange. The hum-inducing 6 volt wall wart I was using generated 10 volts and didn't fry my Grundig. A miracle. Lesson: Test voltage output before using.
The AGM battery together with the charger doing its charging thing noise-free generates only 8.3 volts, so I'm not concerned about that.
I also installed a cheapo volt meter on top of the radio - see photo.
I have the Satellit 750 also. I purchased rechargeable D Batteries and haven't looked back. I still use the power cable but only when I need to recharge my batteries.
  • @ 357:
    holy man no activity or what?
    357 has left the room.
