Take a pic of the Squelch pots wiring; including its color code before you proceed.
Set the control to mid-point.
Unsolder all the pots wires from the pot - either from the board, remembering where they go, or at the pot itself - since it's mounted - removing a combination usually a combination of one wire here (on mainboard) and two there (on control) as an example - might help more.
Using a DVM - set to 20K or 200K test two terminals - does an ohmic result show?
Do, the same thing with one terminal being the SAME and testing the other side - do you get an ohmic result?
Now, remember that SAME terminal? Don't use it for this last test - test the other two terminals.
If all terminals show ohmic results - use the lowest ohmic setting to test without it showing OL or 1.000 (no result or ohmic too high to obtain a result from that multiplier setting of the DVM)
IF all show ohmic, is your DVM on the lowest multiplier setting it can be for testing the ohmic structure and substrate?
Rotate the knob to change the position of the wiper arm - then retest - now you can develop an idea of which leg of the pot is the wiper arm variable.
Example, a 50K pot, and a 20K setting on the DVM - it will show OL - which can give you a "bad result" (open line or out of range) So remember to set the DVM to the best multiplier range to test the ohmic value of the pot - so in this case - the 200K setting is correct to use - you'll get results on all leg tests if the pot is structurally sound.
- You can get readings - but they are in error - even on a bad pot - you can be led to believe that part is still good because of the reading. So you'll need to remember the pot swipes from left to right - but if the pot opened up on one side - the swipe will still show - but as a VERY HIGH ohmic reading (above 500KΩ) so pay attention to the pots own ohmic rated / stamped on the back - usually a 103 means 10,000 or 10KΩ)
- In the schematic snipped above the pot is a 100Kb refers to LINEAR taper (B) and 100K Substrate - or 104.
- There is also the issue of reversed wiring - the Ground to the pot goes to a FIXED value terminal (where the two terminals have the same ohmic value no matter which way the wiper arm is turned) I've seen wiper arm go to ground in error - so be aware of reattaching wires - one - board ground is at a FIXED terminal - Wiper heads off BACK to the board - the power supply to the pot COMES from the board off of a 10K resistor.
IF the pot is open on one side - you can still make it work by reattaching the wires (usually two) and just reverse the wire color code to the two terminals that still show ohmic - just remember you may need to reverse the wire color code to those terminals.
In the above snippet - the 6.8K resistor connection also needs to be reversed to the other FIXED value terminal. (If you decide to keep the pot - knowing it will be reversed in operation - else just replace the pot keeping in mind the terminal layout - which two are fixed and one being the wiper)
Refer to your pic you took at step 1.
