Can you add course/fine clarifier to Grant-XL or Cobra 148GTL?
Thanks for the replies everyone! It's nice to know there are still some of us out here that are still interested in this mod.
As more luck would have it, I also ran across this write up on the mod. I actually found this years ago, but I forgot about it until I re-discovered it.
The write-up does caution about finding the 1k/20k pot. Apparently it was nearly impossible to find it back when whoever wrote this mod and it's not much easier today. I have NOT been able to find an Alps pot as it suggests, but I DID find something at CB World that I think will work. It is for a Galaxy DX88HL, but it looks like it should work for what I want to do.
Get the pot here:
The 10-turn pot will really smooth out fine tuning. Best I can recall, a 10-turn dial for it costs several times the price of the multiturn pot. No trick to see where a single-turn pot is positioned. All you need is a pointer on the knob. A pointer by itself won't tell you how many turns from one end you have spun it. And if the radio has a frequency display that follows the clarifier you probably don't need a dial that shows where you are.
Not every radio's face plate had room for the turns-counting dial.
Reactions: walterjn and NZ8N
Yes, the 10-turn does work well and I have one in my base station. The problem (imo) with a 10-turn in a mobile is that it can be difficult to find center frequency again. A frequency counter would certainly help, but I don't have one in my truck. And as you know, spinning the pot several times can get tedious.
I thought about a 3 or 5 turn pot. That might be ideal for a mobile precision pot, but they aren't easy to find, or at least I haven't had much luck. Thus the reason I thought of my old 148GTL-DX. The course/fine was awesome.
I'm old school like a lot of you. It's hard to get rid of our old rigs as they're too much fun to tinker with. I'm going to upgrade one of these days and get a true 10 meter export radio. I'm not sure which one yet as I've been out of the loop for years. I'm leaning towards a Galaxy though.
Its hard to find a good export anymore, gone are the daus of the galaxy 88/99 and the silver face president jackson, for some reason the new ranger made radios have dropped fm like the ric 99 and galaxy98hp. I ended up going with a lincoln 2+, but my cobra 138xlr is in the mobile until fall because I know it can handle the 110° heat.
Reactions: ShakyMcQuiver
You can get a '3590' 20k 10-turn pot for less than $10 on average. Or at least a Chinese model. No the greatest quality, but they work. You can get them even cheaper if you're willing to wait for them across the pond.
I'd like to try a 3 or 5 turn for the mobile. I bet they'd work good too. Expensive though. Not a lot of sources for them.
Hey all. What can I expect if I find the right person to "peak and tune", a grant xl. I have an old one that nothing has ever been do to but, I thought I might break it out again and see what kind of performance can be done to it without going over board. All info greatly appreciated.
Other then a properly done alignment, having the AM dead key set where you want it, and maybe a clarifier unlock that would be it. The Grant xl is a great old school low powered radio. I would not try to turn it into a 40 watt radio by over modding it. Get a KL-203 if you need mopowa.
