Weird Observation on Solid State Power Supply
Wire Weasel
Senior Moment
Dec 13, 2008
3,253
923
223
Posted this occurrence on earlier thread. Noticed several months ago when running my HF rig on the Megawatt S12 400 I think it is .... the 36 amp one, that it was spewing spurious noise every 5-8kc between around 15-23mhz making those freqs nearly unusable. Mainly took away 15 Meters from me. Otherwise was no problem in the other frequency areas. Okay - now the setup was in an outbuilding workshop being fed by 125' feet of extension cord from the house. Web searches indicated that others have had the same issue including a fix whereby you beef up the filtering on the back end of the supply and that is also referenced in the previous thread.
Since then I've been able to relocate a new HF all band antenna closer to the house and so have been able to move the radio indoors. I have been using an Astron RS 35. It developed a problem which I have fixed but it was down for about 2 weeks. So while the Astron was down I went back to the Megawatt to stay on the air. Well here inside the house with it plugged into the wall there is NO LONGER any such noise coming out of it anywhere.
So I am wondering if being powered by the 125' run of extension cord - the cord was acting as an antenna or something and inducing the supply to create or pass along something that was being picked up by this long run of cord? I can't think of anything else accounting for it to produce this noise in one operating location and not the other.
Any ideas?
Any ideas?
Wow! A125' extension cord? Is it a 10 gage / 3 wire extension cord?
Wow! Only 14 gauge? Have you checked the loss?
Apparently not much. That's not extreme at all for AC. Never any issues with running power tools like big saws or the radio setup. Now DC would have been a considerable issue.
Well maybe.
It might be the voltage drop, 100 feet of hardware store cord , 14 gauge plus 25' more... That's a long run.
If you got 115 at the plug, I would guess the drop gets you 102-103 volts at the end maybe.
Those light duty cords are really light duty.
There's lots of stuff in switching supplies that make noise even the regulator circuit itself.
If on demand you are pulling the voltage down to less than a hundred volts input to the supply maybe that's causing the noise?
Guess?
I would hazard a guess, that the inductance of the long cord causes the voltage to be out of phase with the current thereby causing the high frequency input of the supply to generate harmonics.
I could be totally wrong, there are so many variables. Glad you figured something out.
Never bothered to take any measurements as I've never had any power issues in the outbuilding .... but just for guys I did today.
Fluke 87 III
VAC at back porch outlet 124.3
VAC at end of 125' 14G cord 124.3
VAC with 10" corded circular saw running 120.7
Fluke 87 III
That rules out voltage drop, it doing much better than I expected out of 14 gauge at that run.
Reactions: Wire Weasel
How would one see or measure this effect with a test instrument?
You could use a Field Strength meter I would think. I made one out of a $12.00 analog (big box store purchase) battery tester/volt meter.
It looks like this.
A couple of diodes a variable resistor and a capacitor is all there is to it (I think), Its been a few years so......
Schematics available via Google or............
David
Voltage drop is the same for AC as it is for DC. V= I squared R. That formula is the same regardless of AC or DC. Perhaps you meant that with the higher voltage less current is drawn which will result in less voltage drop. I just wanted to clarify that for the same reason people think that FM will not skip because they equate FM to FM broadcasting which is on VHF. In this case we are comparing DC to 60HZ.
CK is correct! However, when calculating Voltage Drop in a DC circuit one must remember that the TOTAL length of wire used must be considered.
EX. AC= Source to Load distance measure point A to B
DC = Source to Load is point A to B x 2...you must calculate Total length of wire (total resistance) used for both +/- leads
I have a 35 year old 100 foot extension cord. It was used by the welders on a union contract and after the building was built they threw it away! It is still going strong and for the last 6-8 years has been powering my second fridge out in the garage.
