Re-claim 16 LSB contest Dec 24-31, 2022
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,633
1,566
173
The Great White north
OK folks, here it is.
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 16 LSB
  • Date/Time: 0001 24 Dec - 2359 31 Dec UTC. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • FCC rules, regarding CB. While that was neeeded to be said, we need to be good operators using our equipment. Our actions reflects on the forum as a whole.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rule.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
For today's LSB 16 efforts, I'm running my 1981 Realistic TRC 490 with a Turner Super sidekick driving my Starduster clone. It is a 100% untweaked, barefoot set up. Let's see how it does.
So far, LSB 16 is quiet and there isn't much coming on LSB 38 either. With this cold weather, folks all across the country will be staying indoors. Let's hope the propagation picks up and give them a chance to make some contacts.
It was 8 degrees Fahrenheit in Delaware this morning before the sun came up. Now it's 11.... Big storm front came through yesterday, but all we got was rain. If it is going to be this cold, the least it could do is snow. We used to get big snow here, but in the past few years it has been just about nothing. I really miss the snow.
Wind yesterday was gusting over 50mph, so I tipped my antenna down. Let me get a few cups of coffee in me before I go outside and crank it up and we will see what we have for conditions.
LSB 16 has been pretty quiet this morning. Before the contest was posted, the LSB 16 group had set up a start time for our net of 12:00 noon eastern/11:00A.M. central/9:00A.M. pacific. I'm expecting things to pick up around then.
Reactions: AmericanEagle575
