10 Meter Ham Stick
Thanks. I want to experiment a bit with two hamsticks in a dipole configuration for 11 meters.
Do that, and then build an 11 meter dipole using the usual formula. Mount both antennas at the same height and try A/B comparisons between them. I think you'll find that a dipole made to the usual dimensions will outperform shortened ones by a mile. Or kilometer.
If the only difference is a mile or so in distance covered, why bother? ;) OK I'll be quite and behave now.
:ROFLMAO:
Reactions: wa373 and Riverman
