Anytone at-5555 PLUS
Before starting you must have the radio hooked to a dummy load or antenna. Also get a pen and paper and WRITE DOWN EVERYTHING!!! DO NOT SKIP THIS STEP even if you don't plan on changing anything. Scroll through each menu item and view the data and WRITE IT DOWN!!! Make a spread sheet of the menu item and parameters.
Service menu is accessed by starting with the radio in the off state, press and hold function key and continue to hold while powering on the radio, continue to hold the function key then press the other keys on the top row one at a time and in order then release function key.
Menu items are scrolled with the channel selector. You can view the data of selected menu item by keying the mic. You change data by keying the mic and using the channel selector. Once things are set how you want power cycle the radio.
FM high power is menu 8
FM low power is menu 9
FM modulation is menu 11
AM high power is menu 15
AM low power is menu 16
AM low power modulation is menu 18
AM high power modulation is menu 19
SSB high power limiter is menu 21
SSB low power limiter is menu 22
SSB low power is menu 25
SSB high power is menu 26
Those are the main ones that most ppl can set themselves.
On the AM modulation adjustments smaller values equals more modulation(Less AMC clamping).
Like I said before WRITE EVERY SINGLE PARAMETER DOWN, ALL 53 OF THEM!!!
Don't break you radios! I'm not liable! These are alignment settings, resting the radio will have no effect on these!
73' Panic Attack
Thanks for posting this information I was able to peak and tune my new radio I was able to lower the am dead key and turned up the Am low power modulation and it now drives the Texas star dx500 I have pretty darn good I get good audio reports on a.m. when running amplifier or just or just the radio by itself only SSB adjustments I made was I turned up the radio SSB high power so when I talk on SSB without the amplifier then I turn the radios RF power knob up 73's and God bless from 112 Southern Illinois
"Damn good radios better than the Lincoln 2 plus and cheaper and does more stuff like the Lincoln 2 plus only has six digits on the frequency display and this radio has seven digits that makes it easier to fine tune someone in on SSB"
For the record, I didn't post that originally. Not sure who did or in what thread, but it wasn't me. I don't mind being quoted, as long as it's something I actually posted.
Reactions: Shawn Peshoff
Oh okay
Your welcome
By the way some menu items require specialized test equipment and procedures to adjust and if the parameters are changed without the proper test setup you can't just put them back. I recommend only adjusting the modulation and power menu items. Great job.
73 Panic Attack Illinois Bottom Side
Your welcome
I only adjusted power and modulation is this Matt?
Yep. I just realized who you were as well. Thanks for the information on the radio this Texas Star dx500 I have I think is one you used to own because it has the name Copperhead scratched into the inside of it from 2007 did you scratch your old CB handle into a Texas Star DX 500 on the inside of it? They might have been another Copperhead out there somewhere
Exactly. I've posted about the max mod a few times.
It's not that the MAX Mod is snake oil. Putting a beefier regulator in is old school upgrade. The part that is kind of misleading is how it is marketed.
Back int he 1990's It was 2SA1301,1302 and SA1943 I still have like 12 of the 1302's and 3 of the 1301's and I think I have a Max Mod or 2 some place. TIP36 will do similar and the TTA1943 is great as well. The MaxMod is not snake oil they just have too much hype and crappy sleazy people push them as if they are the end all be all! I think they are a solid part just over priced.
If you do not squeeze the radio for every single watt you can get out of it the stock regulator is fine!
73' Panic Attack
what is ssb high/low power "limiter" (menu 21, 22)? is it ssb ALC?
