Can't believe the dummy load prices!!
Greg T
WDX-945 (Jazz Singer) Upper Peninsula of Michigan
Sep 18, 2014
1,465
2,510
273
72
Escanaba, Michigan
OMG! I was just net surfing radio stuff and ran across and wet 1kw dummy load selling for $128.00. I laughed out loud, thinking this was one of those Ebay-type sales. So, I poked around looking at others and could not believe what I was seeing! Cheapest I found was about $85.00 and they went up to $149.00. The reason I mention this is because I bought mine in the mid 90s for $17 and some change. Yes, brand new, in the package, including the mineral oil. Yes, a versa-load. What happened??
Reactions: G-Golly Wally
You can get a 50Ω 450w flange mount RF resistor good to 1.7GHz for $24 on mouser.
i want to make a DIY dummy load. i love to tinker taking junk and making something out of it. there is a popular Paint Can dummy load which i believe started as a Heath kit called the 'Cantenna'. a paint can filled with Mineral oil to do the cooling. i'm thinking of making a quart sized one as i will never need anything over 100W. i do want a point i could attach scope test leads. just guessing, but the can should help trap the RF. not sure how much more RF you would be emitting with just a resister bolted to a heatsink. perhaps a Faraday cage :unsure:
would be interesting how cheap you could make one.
i've heard of Salt Water dummy loads in glass jars. doesn't sound very good for trapping the RF though.
cheers
/richard
Reactions: brandon7861
i wonder if they can be used for a dummy load? it doesn't say if they are non inductive or not. if they will work for an air cooled dummy load, you can build a 5kw load for only $285. i will totally buy a bunch if they can be used.
Yes it can. Not only is it listed as an RF part for up to 1.75GHz, but the datasheet has a return loss chart. At 27MHz, it looks llike it is just below -25dB (which is an SWR of 1.118). It cannot be too inductive with an SWR of 1.118.
I bought a pair of 100 ohm 800 watt flange mount devices and wired them up in parallel, with each resistor having it's own heatsink. I bought mine from Florida RF. They work well for air cooled high powered loads.
nostalgia,,,, my first dummy load back in early 70s was a 100 watt light bulb and light socket , probably just a few dollars but worked for 4 watt cb radios,,,,, i also later had the pl259 and bayonet bulb dummy
View attachment 63264View attachment 63261View attachment 63262 View attachment 63263
cheers
/richard
There are lots of different ways to add an RF Sample port to a dummy load, but one simple way is to do what you see here (for HF/VHF use):
-40dB is pretty much perfect for connection to your test equipment, and I have found this simple resistor voltage divider option to work very well at HF/VHF. Remember to keep the resistor leads as short as possible.
