All are 12 volts and only one is original unless someone cut the wall wart Off of the other two or added a wall wart to one of them.what is the rating of the power adapter that you use are they original
Of all the adapters i have laying around closest one, i found is 12 volts at 1amp i think i need closer to 0.3ampsAll are 12 volts and only one is original unless someone cut the wall wart Off of the other two or added a wall wart to one of them.
That one will work just fine.Of all the adapters i have laying around closest one, i found is 12 volts at 1amp i think i need closer to 0.3amps
You are going to like it. I put an RF pickup in the remote box on one of mine to hook my scope up to. Just a BNC socket and a wire looped several times loosely around the guts and then connected to the case. The back light in all 3 of mine went out, have not gotten around to looking at them. I believe the meter has two grain of wheat bulbs in series. If I could find a soft white led I might try it. Let us know what you think.After hearing about these for so long I finally bought one last week. I sure hope it lives up to the hype...
It's coming from Alaska via snail mail but should arrive eventually, I hope.
I appreciate your input sir. I took a shot and we'll see what shows up. It's pretty clean for It's age and the seller had praising feedback so I'm in hopes that it'll be all good.You are going to like it. I put an RF pickup in the remote box on one of mine to hook my scope up to. Just a BNC socket and a wire looped several times loosely around the guts and then connected to the case. The back light in all 3 of mine went out, have not gotten around to looking at them. I believe the meter has two grain of wheat bulbs in series. If I could find a soft white led I might try it. Let us know what you think.
Try these, perfect size to replace grain of wheat incandescent bulbs in electronics. I bought this kit a fee times now and they've been some good LED's. There's a soft white that would be a nice upgrade for the stock bulbs in that meter.
Hard to tell without removing the meter cover. I don't think he offered the lighted version until late in the production. I know the original lamps went out pretty fast, but then it's on 8 - 12 hours a dayThat looks really good, nice bright light that doesn't burn the eye's. Nice install too.
I don't know if the one I'm getting is lighted.
i'm feeling jealous mine don't have the lights but i'm very happy with the meter especially the swr section no adjustment neededTo my surprise, it's really on par in readings with the daiwa cn-901hp. I only tried a couple of radios so it wasn't extensive but nice to know!
That's one neat feature that I forgot about, it will measure SWR while you are modulating. Really handy when trying to diagnose amplifier tuning problems.i'm feeling jealous mine don't have the lights but i'm very happy with the meter especially the swr section no adjustment needed
