Just Got my brand new ICOM M803 installed and it’s giving me headache
Ning25
New Member
Oct 27, 2023
4
Well, I am kind new to SSB Radio, since all I have used in my life are VHF Marine radios, now this time around I decided to purchase an SSB Marine radio so that I can have communication to the land everytime I am offshore, thus I bought two Radios, once of which I installed at my Home Radio Base Station, and another one witch I am installing on my boat, as soon as I can figure out why the radio is not working properly, since all I am getting from the Digital watt meter is,FWR: 4w and 99.99W for SWR, I am desperate cause I spent so much money on something that I assumed was a piece of cake to install, I just don’t know if there is something to do with the coaxial cable or the control cable, since I had to cut and add another conector to it at the end of the transceiver in other to match the female’s, I didn’t even open the Auto-Tuner cause it’s a brand new AT-140 tuner as well as the Shakespeare 393 SSB antenna. Can someone please help me to troubleshoot it, I am really a newbie when it comes to SSB Radio.
Welcome!
It could possibly be a problem with the coax connector you replaced. Can you check it with a multi meter set to ohms to see if there is a short from the center pin to the coax shield?
