It is for sure a Cadillac. I have the one with 2 toshiba 2290's on the belly, its the 95T. Both are real nice radios on SSB TX and RX.
I did Robb's drift mods to it and replaced the X3 crystal with a 14.460. I like it even more now as the warm up time and drift is greatly reduced.
Both have the Ranger 690010C board. The 98VHP has the D version board but with mosfets on the drive and belly amp which I don't like.
Its definitely a keeper radio. The 93T, 95T, 2517 all share the same nice quality board.
The only radio I ever sent out in my life was to Chris at Superior CB 6 years ago, due to parts needed that cost more individually to buy, was a Magnum S9 which had the amp on the bottom but prior to my purchase was removed so a lot of SMD parts were missing in the final section, and one modulator SMD IC that was bad which cost a fortune. It needed more parts to run without the amp on the bottom. Anyways they did a great job of it and it cost me $80 shipped back.
Do you know if he replaced the the 2sc2312 transistor on the amp board too? Did he send your old parts that he claimed were bad back to you? like the 2sc2290 final?
Please post a picture of the final section in the back so we can see what he did.
Most likely not your problem but I found this on the galaxy symptoms and cure data base and if it was posted there that means there are many 93T's with this issue.
| Posted By | Galaxy Tech Support |
*****R9 is a zero ohm resistor that acts as a jumper*****
