Delta Electronics DSP60M for $189 yes or no
Maxafterburn
New Member
Mar 24, 2024
So I'm in the market for a power supply for my President Lincoln that I am planning to set up as a base. I see this unit advertised for sale directly for $189 brand new. Then I have seen it advertised used for $150-$325 depending on where you look.
#1-is this a decent power supply?
#2-is the $189 version the real deal or some scam? https://www.deltaelectronicsonline.com/ProductDetails.asp?ProductCode=Delta-DPS60M
Thanks,
Ken
Delta is so so, I'd suggest an mfj or jetstream over a delta supply and probably at a better cost. The ones below are plenty to power that president.
Just my own opinion
125.00
125.00
That's the most preferable if you don't mind getting creative with the power terminals. Really the best bang for your buck. I use one (35 amp) on the experiment/work bench and it's been going for about 5 or 6 years now.
Reactions: BC Coyote
I am old school and really like my Astron 70m and 35m. If I was going to get something else I would get a Mega Watt, several locals have them and they work great.
Reactions: codeman
Big Thumbs up for Megawatt. I bought a 36 Amp version. It's tiny, quiet, doesn't create any interference and didn't cost a fortune. It also runs all my gear perfectly. Couldn't be happier.
Reactions: codeman and wjm1129
I currently use 3 of the 50A models because the 50A are made to be ganged without an external current sharing circuit. I use two in parallel for my DX-500 and a single one for my radio.
How many amp tops can the dx 500 use?
I've not really checked mine accurately. But, I have a meter that shows about 47A when using SSB. I never use it on AM so I cannot tell you about the dead pull. I've got a clamp-on meter and when I fire it up today I'll hit it hard and get a quick peak on it for you.
Reactions: Keto
JETSTREAM JTPS60M​
JETSTREAM JTPS75BCMMKII :giggle: (y)
  • @ Spanish:
    Where do i upload schematics
