My updated shack!
Nice touch with the sound treatment on the walls.
What rotator are you using on that Yagi?
The rotor is the Yaesu G800-DXA and I use the Hy Gain YRC-1 rotor controller which provides both manual and computer control that works with many rig and rotor control software programs I use like HRD, N1NM Logger, and PstRotatorAZ.
I ony wish I had the antenna at least 45 feet!
The sound proofing is nothing more than matress padding Walmart sells but it works and looks good enough. My friends call my shack the padded cell!
I occasionally record music demos so my shack is a home recording studio as well. That's what the padding was put up for.
Thanks for noticing!
Really nice looking station. I am jealous lol. I am going to redo mine this summer. Hope it turns out half as good as yours.
Thanks!
Be sure to post pics of your station when you get it up and running, many of us like looking at other members shacks.
Good luck with yours!
And what is the mast shelf / clamps being used with the rotor and the thrust bearing?
DXE sells the rotor platform but it was out of stock when I was looking for them.
I bought the same pair direct from a company in Germany for fifty bucks cheaper with shipping. I also bought the thrust bearings from them which were priced good and to be sure they matched up with the platform holes.
The bearing holes are supposed to match up with Yaesu thrust bearings and rotors. My rotor and bearings were a perfect fit.
I do strongly recommend you use 2 rotor platform plates and thrust bearing if using a heavy antenna on a pole like I'm doing. I believe you can see why that is.
Good morning:
Do you have any photos of how your assembly with the GPG-60 platforms turned out? I've found some information about them, but nothing concrete. I'd love to see a real assembly of these platforms already installed with the rotor down and the discharge bearing in place, etc.
Thank you very much and best regards.
Good morning:
