I have a Apollo 500 and the transformer is bad it is a 1300v can I replace it with 2 transformers out of a D&A Phantom they are around 850v i believe. Here is one from Apollo.
It appears that transformer has been operated above its maximum altitude of 12,000 feet... I'm assuming this amplifier runs sweep tubes and 900 to 1,000 volts AC before rectification and filtering, seems very high for sweep tubes. As I recall the D&A transformers are 660 volts AC. They work great with a full wave bridge rectifier on sweep tubes.I have a Apollo 500 and the transformer is bad it is a 1300v can I replace it with 2 transformers out of a D&A Phantom they are around 850v i believe. Here is one from Apollo.View attachment 70247
To answer your question: The change of a different transformer, will most likely require additional work, unless it is a direct replacement. (which the D&A's will not be) rectifier config/Cap configuration...possibly many more components and circuitry will need to be examined. IMHOI have a Apollo 500 and the transformer is bad it is a 1300v can I replace it with 2 transformers out of a D&A Phantom they are around 850v i believe. Here is one from Apollo.View attachment 70247
The 170 volts is the maximum that the full primary can handle. The rated voltages are printed on the top. With a primary of 115 volts, that has an additional 4.3 volt winding, that could be added in series to make less than a 5% drop in the secondary voltage. I don't see how to get below 900 volts AC out of this transformer, when it was working. That works out to be a no load voltage of over 1270 volts DC. The most I've ever seen on sweep tubes being used in a linear amplifier.Running 125 VAC on 170 VAC primary windings would drop B+ down to something closer to "Normal" :-0 (still 1000+VAC) ...I am thinking this is some surplus Xformer they grabbed for price and made it work. D&A did the same...never knew until the covers were off to really know what you had. (and sometimes not even then!)![]()
I was always told to be careful doing that, using a center tap transformer for a full wave rectifier in a full wave bridge and not using the center tap. I was told that sometimes the installation is not rated high enough for that across the transformerIt appears that transformer has been operated above its maximum altitude of 12,000 feet... I'm assuming this amplifier runs sweep tubes and 900 to 1,000 volts AC before rectification and filtering, seems very high for sweep tubes. As I recall the D&A transformers are 660 volts AC. They work great with a full wave bridge rectifier on sweep tubes.
That is true however, the transformer in question, from the D&A amplifier was designed to be used with a full wave Bridge rectifier. Since the original transformer doesn't have a center tap, this should be a good replacement, with plate voltage that's appropriate for a sweep tubes.I was always told to be careful doing that, using a center tap transformer for a full wave rectifier in a full wave bridge and not using the center tap. I was told that sometimes the installation is not rated high enough for that across the transformer
From not so fun experience, I can tell you that the breakdown voltage on the D&A transformer, is three secondaries. Put four secondaries in series and a humid day will find the breakdown voltage.The D&A transformers have no such limitation built into them. They were meant to be compatible with a full-wave bridge rectifier circuit.
