need parts or its for sale
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
4,333
6,383
523
70
this much sought after radio decided to go channel blank.its not lost connection but segments are dead. anybody know where i can get replacement for the readout? if not its for sale. sadly i got it set power wise to run my kl 203
I had that problem once with a Cobra 29 and a broken display. I sprayed CRC contact cleaned in on the channel changer knob and got my display back again. Can't guaranty anything but it might be worth a shot. The display was still working the last I tried it but it has been a while because it was a AM only radio. And I might have got the cleaner on more than the channel changer knob.
Reactions: Rwb
That is a common part. Common anode 2 digit display. May be a TLR321, but going from memory, that is going. Should be no problem obtaining a usable sub, based on dimensions and footprint.
Reactions: Rwb
Yes those 2 digit displays are not hard to find. If it's a common anode they're sold at many of the cb shops, if it's common cathode it will take just a tad more to find one but they're still obtainable.
Reactions: Rwb
ive sprayed the selecter and no change. got it used who knows whats went in its system voltage wise. i did manage to locate set in green from workman
Reactions: FlyBoy50
Like they say Beauty is in the eye of the beholder. Sometimes Hobbyist are a crazy bunch. LOL And I should know when I look on the shelves of my radio room.
Reactions: Rwb and Eldorado828
I have the Workman parts here. Or, I'll get you a Kingbright sub part number when I get to my bench. I am working on other projects this week. You can get the Kingbright from any parts house.
Reactions: FlyBoy50 and Rwb
That is one that Uniden built for Rat Shack, it's a Uniden 122xl on the inside. Current trending price on E-Bay from completed listings is 80-299 dollars. Most are selling for 100-150.
It was a good laugh this morning that the radio is worth $20. :) I would be glad to pay $20 for one. I kept all of my TRC-465 radios. The Uniden 122 is the same but for some reason that one on AM does much better vs the other 4 TRC-465 radios I have.
Schemo for a PC122XL Uniden says it's a "UR202AD".
No idea what substitute number will cross-reference to it.
Now and again a ballast resistor will fail and the segment that it feeds goes dark. When multiple segments are dark, I suspect the LED display.
