need parts or its for sale
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
4,367
6,447
523
71
this much sought after radio decided to go channel blank.its not lost connection but segments are dead. anybody know where i can get replacement for the readout? if not its for sale. sadly i got it set power wise to run my kl 203
I had that problem once with a Cobra 29 and a broken display. I sprayed CRC contact cleaned in on the channel changer knob and got my display back again. Can't guaranty anything but it might be worth a shot. The display was still working the last I tried it but it has been a while because it was a AM only radio. And I might have got the cleaner on more than the channel changer knob.
Reactions: Rwb
That is a common part. Common anode 2 digit display. May be a TLR321, but going from memory, that is going. Should be no problem obtaining a usable sub, based on dimensions and footprint.
Reactions: Rwb
Yes those 2 digit displays are not hard to find. If it's a common anode they're sold at many of the cb shops, if it's common cathode it will take just a tad more to find one but they're still obtainable.
Reactions: Rwb
are the segments dead? did you put too many volts?
It might be the selector is dirty. take the knob off and put the shaft in your cordless drill chuck and go slow but let it go awhile then back the other way and see if it wakes up.
dont floor it
ive sprayed the selecter and no change. got it used who knows whats went in its system voltage wise. i did manage to locate set in green from workman
Reactions: FlyBoy50
I have the Workman parts here. Or, I'll get you a Kingbright sub part number when I get to my bench. I am working on other projects this week. You can get the Kingbright from any parts house.
Reactions: FlyBoy50 and Rwb
That is one that Uniden built for Rat Shack, it's a Uniden 122xl on the inside. Current trending price on E-Bay from completed listings is 80-299 dollars. Most are selling for 100-150.
It was a good laugh this morning that the radio is worth $20. :) I would be glad to pay $20 for one. I kept all of my TRC-465 radios. The Uniden 122 is the same but for some reason that one on AM does much better vs the other 4 TRC-465 radios I have.
Schemo for a PC122XL Uniden says it's a "UR202AD".
No idea what substitute number will cross-reference to it.
Now and again a ballast resistor will fail and the segment that it feeds goes dark. When multiple segments are dark, I suspect the LED display.
