Inspect Your New Amps
Recon
Jul 28, 2019
1,300
1,442
173
New amp arrived and I was curious as to what type / name of the pills were installed. I removed the cover and found two defects as per the attached photos. Both cables are not secured to prevent them from being pulled-on the soldered connections. Any idea what the floating thick washer-looking object is?
That round donut looking thing your pointing at in pic one is not there to secure the cable. It's a magnetic ferrite choke. I think X-Force amplifiers used to come that way.
Reactions: Cable Guy
Yes, I realize it is not to secure the cable, I just did not know what it was. For crying-out-loud, it can't cost that much to use and install a watertight strain-relief grommet to ensure the cables don't get pulled-out.
I've seen some of the amp builders use string and do a fancy little knot to keep the ferrite in place.
A strain relief on the power cables should have been a default. Nylon cable glands work really nice for those.
I would definitely recommend installing a strain relief. Or at least something to protect the wire's insulation from the sharp edges of the cabinet.
There are plastic pass-through grommets installed to prevent chaffing. A five-cent Zip-Tie would be better than nothing to prevent the cables from being pulled-out.
Reactions: Onelasttime
Does this amplifier have a name on it?
Might be worth knowing who to stay away from.
I'm not disclosing the manufacturer of the amp, because I was informed that this is just about the "norm" with many amp and power supply builders. I recommend retaining the photo and if and when you or anyone orders a new amp or power supply, forward the photo to the builder and ask if that is how the power cables will pass through the cabinet.
Imagine a car forum and someone is warning people about an engine problem but then refuses to tell people the Year, Make, Model, and Engine type! It would be a worthless post of no use to anyone!
At the very least put a zip tie on that wire until you can get a proper strain relief.
That power wire is not soldered down well.
I think it is low class to complain and make a PSA lacking most of the basics of "Who, What, When, Where, Why". Have some courage! If this was a new amp from Texas Star or MFJ you would share it. You are clearly afraid of fall-out from the builder community and their fan boys!
I would add that if the amp is installed properly and bolted down and the wires are ran properly there should be a very low chance of a strain guage being needed even if it is clearly best practice. Anyone that has worked in car audio, 2-way-radio, or as a mechanic have seen how poorly people install electrical and electronic gear in car's and trucks! Bad construction methods and installation practices have burnt peoples trucks to the ground!
Reactions: Mudduckmobile
This may be an XForce product.
Look at the marking from the sheet metal brake, the clear-backed stickers, and the offset on the bottom of the amp.
