Last year, somebody left on my porch a TRC-451..with a paper note saying "for you"..hopefully wasnt a death note since Im still alive..
K, I just left there around until yesterday..opened it up, of course driver and final were removed, but the radio seems pretty much intact..so put a 10m ant, no signal..pulled out my TinySA on the antenna connector with a 27.025M AM modulated to 1k, no signal. no AM or SSB. so I made a direct coiled probe and setup the TinySA to 10.7 and kind of moved the probe around T14 to T17 and I got signal..so then I was probaby a UmD 2824 pll problem..so I checked the binary inputs of the PLL and there is no 5 volts,according to the service manual, on any of the PLL binary inputs..
Bad PLL? If I remove the PLL, would I see 5 volts on the channel selector pins? channel display seems ok, when I turn the channel knob, it goes from 1 to 40..
