icom&ameritron
1iwilly
Dec 7, 2008
916
656
103
64
I'm picking up an Ameritron AL-811H, and I'm using an Icom IC-746 nonpro if I don't use the alc port, can i use the send RCA from the radio to amp relay port to key the amp ?? or would i need a foot switch for the amp
You can try the foot switch first to see what happens. I am using Yaesu FL-7000 amplifier with a foot switch for 4 radios ( I select radios by using an antenna switch ). I run an Icom, a Yaesu, a Striker and an Anytone 6666. It’s working fine.
Reactions: 1iwilly
i assume you key both at the same time or radio then amp my othe amps didn't need anything extra to make them key
Yes, your assumption is correct. A foot switch is generally required when the ham amplifier brand is different than the transceiver. Just a foot switch connected.
The radio's 'send' jack on the rear should be compatible with Ameritron amplifiers. The schematic shows a relay in the radio connected to the send jack. You should be good to go with just a patch cord with a RCA plug on each end.
Oddly enough the owner's manual fails to mention any limits on what you may switch using the send jack.
Yes i found a heavy-duty 90-degree RCA cable it's working radio is keying the amp thanks for the replies
Being of different brands has nothing to do with it. An Icom radio can key a Kenwood amp. A Kenwood radio can key a Yaesu amp. A foot switch is required when the radio does not have a send port such as when using an 11m radio with a ham amp. Some older tube type amps require either a slight mod or the use of a foot switch because the voltage/current required to key them is beyond the capabilities of the relay in the driving radio.
This is not the case. Send is nothing more than a key line to ground, when the radio is in TX. It is not brand specific. The only thing of concern, is the keying voltage of the amps T/R relay, which may exceed the T/R relay or send circuit of the radio, which s why there are amplifier buffers.
Captain Kilowatt and SuperLid.
You are right. If the transceiver doesn’t have a Send RCA, these type of amplifier won’t work. In my station, I have 4 transceivers, 2 HF and 2 CB transceivers. For obvious reasons, CBs don’t have the Send RCA like HF transceivers to activate a HF amplifier. In my case the easiest way was a foot switch. Not a big deal. You get used to use the foot switch.
