I wonder if it is the same as the one in the washington. I see that the grant has the diodes on the switch PCB rather than on the main PCB, but I bet the switch is the same.
Back when I did my excel calc for the 8719, I found out that the PLL data is the same for both the 11.1125MHz and the 11.325MHz boards. The only difference is whether pin 10 is floating or grounded. Since the grant uses 11.325MHz with the same PLL and pin 10 floating, I have to assume the binary is the same as the washington with the 11.1125MHz crystal and pin 10 grounded.
