Diamond shaped antenna identification
nfsus
Yeah its turned off, touch it
May 9, 2011
592
319
Arkansas
I saw a hf antenna and can’t remember the name. It’s kind of a vertical diamond shaped loop that has a coil in the center of the diamond. The diamond looked like it was built out of a 3” wide thin metal.
I think I know what antenna you're referring to, but for the life of me, I can't remember the name. Looks almost like an elongated hexagon with a loading coil in the middle. I'll keep digging.
Looks kinda like this
It's probably the most narrow-banded antenna you can use on HF frequencies. Reminds me of the 18-inch long center-loaded Hustler CB antenna of the 70s. Was commonly mounted on a rain-gutter clip. Remember rain gutters? That antenna would tune to a 1.3 or so at resonance on channel 12 and rise to 2.5 or 3 at channel 1 and 23.
The general rule is that the smaller the fraction of a wavelength your antenna size becomes, the more narrow-banded it will be.
The Isotron is no exception.
Loaded my TS-530 into my White Lightning clone quad on 3675 one night. The radio's internal tuner helped. The 27 MHz series-fed driven element must have looked like about 5 ohms. Should put an analyzer on it one day just to see. The other folks on the sked that night heard me, but not all that well. Probably only because it was winter, no lightning crashes.
Probably a close approximation of the Isotron's 80-meter efficiency. Gotta figure I would have been 1 db below mental telepathy with summer lightning noise.
Reactions: bob85
