Anytone at-5555 PLUS
I always put performance ahead of looks........ but to each their own I guess.
I want my radio to be the best it can be, regardless of how it "looks". To me, this is a hobby where technology and communication are key, not the form factor of the radio.
Yup, me as well. Function over form. Not just the performance, tho, but the ease of function as well. It's why I love the Stryker 955. Most of the functions one would need to access during use is on a knob or a switch. No having to punch thru menus to find the item. I have a brand new Anytone Q6 pro that I used for two hours and then packed it back up in the box and it sits there. Too many menus for me.
I didn't like the "Telephone Plug" Mic setup on the Plus 2. And I didn't want an adapter to change Mic's.
The q5 plus n has a standard plug, it's the N2 that has an rj45 and it's really no big deal aside from using an adapter. In the end the stock mic really works best with it anyway.
Thanks for that reply, but I guess I am old school. I prefer "Direct Connect". "73's.
That is an RJ-45 which is used for ethernet, it is NOT a telephone plug. That is the standard now for nearly all VHF and ham mobile gear too.
I usually use the stock mic on my 5555N2. I do sometimes like to run my Turner CS-1 desk mic on it though, so I made an adapter using an ethernet cable end and a female 5 pin cobra jack I had in a parts bin and just spliced them together. Took about ten minutes seeing as only three of the wires in the RJ-45 plug on the Anytone are used. Nothing wrong with adapters and they are easy to make.
Reactions: jrd426 and 9633
It is interesting to see that many purchase whatever they prefer. Just imagine that people are paying a Thousand or more for an old Browning Golden Eagle. Everyone has different desires and wants. I understand.
That's because there has never been another AM radio ever made that sounds better than a well tuned Browning Golden Eagle Mark III lol.
  • Love
Reactions: Johnny Waggoner
I've also came up with a NPC mod for this rig as well. I will post a pic if I can figure out how.
This was just a preliminary test photo to show location of the mod. The final mod on my radio used, I think, a 560 ohm resistor in series with the diode to limit the amount of negative peak compression. A one K ohm variable could be incorporated and be adjusted for proper wave form for a given carrier for optimal performance over a wide range. If only a diode is used the negative peaks will not make it to zero and badly distorts and flattens the negative wave form.
This isn't a huge swinging mod but it does wake up the radio and give a cleaner sound if the radio is adjusted properly in the service menus.
Hope this helps, these are great sounding rigs when set up properly!
Panic Attack Got Down! ;)
Super old post, but what diode are you using for this mod?
Hi guys,
Anyone knows a audio mod for this model ? I got bout 45w ssb pep, but only 25w rms. I saw a video that a guy did something in the NPC area, and the pep and rms modulation became very close. I think is something in audio limiter or so. Did the NPC mod, but it dont affect the avg/rms powers at all. Any ideas ?
