[SOLVED] Clarifier unlocked. Voltage drops by 0.04v on transmit. Possible remedy?
doffo
Oct 14, 2012
752
672
103
Hello,
It really didn't dawn on me until yesterday when i did the clarifier unlock on an old Realistic TRC-451. I have a Uniden Grant XL under my desk with its clarifier unlocked as well. When I go to transmit on one radio, and adjust the clarifier on the other, I can get it right on. But when I transmit from the radio on that I was adjusting the clarifier on, it is off on the radio receiving....
So that is when i grabbed a multimeter, and measured the voltage from the point the clarifier was pulling from. On Idle, the voltage was at 8.28 volts.. When you transmit from the same radio, it dropped down to 8.24 volts. Not a whole lot, but enough that it will be off in Hertz from where you are listening at.
It is for sure better than a radio without its clarifier unlocked and transmitting way off frequency. At this point I was splitting hairs and trying to get it exact.
Is it possible to add a small board/circuit by itself that will take in the 12v, and put it to a set voltage of 8.00v? This way no matter what if you are listening or transmit, it keeps it locked on 8.00v.
Again, its probably very minimal change, but enough that I am now curious about it.
Thanks for reading. Hope ya'll had a great day.
I don't think it is very important to have it exactly 8v as long as the voltage is the same in RX and TX.
Avoid cheap regulators like the 7808 as they are terrible at ripple rejection and the modulated audio could carry through to the tuning varactor. There are precision regulators like the TL431, but that's probably overkill here.
The most common approach is to use a zener followed by a capacitance multiplier. 8.7v is right in the transition region between zener tunneling and avalanche breakdown and things get noisy there. If you can tolerate a slightly lower voltage, go with an 8.2v zener, or, if that's too low, go up to 9.1v. The Vbe junction of the NPN will drop about .7v of that, so you will get 7.5v or 8.4v that way. In any event, 8.7v is probably the noisiest zener you can buy,
You want to aim for about 8mA zener current to get above the knee and minimize noise.
Here is a simple circuit that will get you a voltage stable enough to use, I recommend an 8.2v zener.
You want to aim for about 8mA zener current to get above the knee and minimize flicker noise.
Appreciate the input! It all kinda goes over my head, but now I realize that a simple 7808 will not be up to the task... In all honesty its ok on the air, but if one really wanted to keep it stable and not move between receive and transmit, that circuit design you drew up would be ideal!
Very easy mod. . . . .
You need to compare the difference between your TRC-451 and the TRC-465.
The voltage regulator circuit for the TX and RX in the TRC-465 had been
up-graded with IC4 (L7808CV, 7808, LM7808), and related parts
Do not confuse it with the IC4 in the TRC-451.
•• In the TRC-451 ... TR34, TR35, and related parts are the regulator
circuit, and they will remain in the radio.
•• In the TRC-465 ... The 7808 and related parts are the regulator
circuit, and are the only three parts to be used
in the TRC-451. (2 caps, a 7808, and wire)
NEW PARTS NEEDED:
1 each - 7808 to include mounting hardware and isolation pad
2 each - capacitors C118 & C119 (Using TRC-465 part numbers, see
instructions "Step 3")
2 each - wires (But maybe as many as 4 wires cut to length needed.)
The data sheet information for the 7808:
INSTRUCTIONS:
◙ Unsolder ONLY one wire, prep and install 7808, solder the 3 (or 4) wires to the radio.
1. The radio will remain with all it's parts regulator parts, only adding the 7808 and related parts to only regulate the Clarifier Potentiometer. All
of the following steps can be found in the schematic for the TRC-465 of the IC4 (7808) and its two capacitors (C118 & C119) forming the voltage regulator.
2. Unsolder the Positive wire from the CLARIFIER Potentiometer at the BOARD, not the Potentiometer.
(This is how to use the 7808 regulator "Step 3".)
3. Using two electrolytic capacitors (for C118 & C119), of the same value, anywhere from 10uf/16v to 1000uf/25. These caps filter the ripple and warbling of the audio transmit and should always be used with an 78XX regulator.
*****(Sorry you didn't know this Brandon.)*****
(The following capacitor connections for C118 and C119 are all the same just mounted in different places. either to the 7808 or to the board and clarifier.)
a. With one of the capacitors (C118) soldered:
* 1. To the 7808 from pin1 (positive output) to pin2 (ground)
OR
2. To the the outside positive pin of the clarifier potentiometer and
the other side soldered to ground. (This is where I think the best place to filter the voltage going to the Clarifier is.)
b. With the other capacitor (C119) soldered:
* 1. To the 7808 from pin2 (ground) to pin3 (positive input) being as close to the 7808 as possible.
OR
2. If you can find a spot on the board, with 2 or 3 holes open, and are very close to where the 7808 would get mounted. With a 3rd wire, run the 7808 pin3 (positive input) to the positive side of the capacitor soldered on the (radio board) with the other negative end of the capacitor soldered to board ground.
* This would mean that at "Step 5" pin3 of the 7808 would end up with two wires going to it (your choice):
a. Two wires from pin3 of the 7808; one to the capacitor, the 2nd to the positive of the "ON/OFF" switch.
OR
b. Two wires to the positive side of the capacitor; one to the 7808, the other to the "ON/OFF" switch.
***c. At this point you should have the 7808 with two capacitors soldered to it, or one on the board and the other at the Clarifier Potentiometer voltage input. (or a mix of both once you decide how the schematic is.)
*** Make sure you match the polarity of the 2 capacitors to the 7808 (pins "1 & 3" are Positive polarity and pin "2 & the mounting stub" are board Negative polarity.
4. Measure all the wire lengths needed, for the following steps, from where the 7808 will be mounted to where the wires have to go. If the length at "Step 6" doesn't reach ..... replace with new wire of proper length.
5. Connect two wires to the 7808, one each at pins 2 & 3. (see "Step 3b2")
6. Solder the Positive wire from the CLARIFIER Potentiometer to Pin1 of the 7808. (The wire that was unsoldered at "Step 2".)
7. Solder the wire from pin3 on the 7808 to the ON/OFF switch to come on with the radio. (see "Step3b2" is needed)
8. Solder the wire from pin2 (ground) of the 7808 to board ground.
9. Insulate and mount the 7808 to the either side of the frame so that it can be used as a heat-sink (just like installing a driver or final)., and it does not ground to the frame.
Disclaimer: YOU ARE RESPONSIBLE FOR YOUR OWN MISTAKES.....
It's all there in the schematic of the TRC-465 (IC4 circuit).....
Just 3 parts and maybe 4 wires.....
Only by-passing the TRC-451 regulator with a 7808 to the clarifier.....
My 2¢. . . . .
Reactions: doffo and MKwrench
Very much appreciated! My trusty Cobra 146 GTL out in the mobile will be brought in as well for some attention. :)
You should always solder the capacitors as close as possible to the 78xx series regulator, even more so in a rf rich environment,
a couple of tantalum caps directly to the regulator legs is good practice,
78xx series regs are poor performers if you are dealing with high end HIFI but they are found in CB & HF radios supplying voltage to various circuits,
usually the radios have chokes & filter caps before the supply reaches the regulator.
Reactions: Gman
Happy to report that using the 2 capacitors and a 7808 worked a treat. :)
Just to be sure I wasn't imagining things, I hooked back up the other TRC-451, and it was off like i mentioned earlier. Put back my Cobra 146 GTL (The one I put the 7808 in.), and it is much better.
I ended up using a spot near the back and a big ol 1000uf 35v capacitors.
Please let me know if the way I did it is a no go or I should go about it a different way next time. (Surely a physically smaller capacitor would be ideal lol.)
@doffo
Very Good, looks like it should have been there.
Did you put a 2nd capacitor in there? It needs two capacitors to work right; one on the input, and one on the output (8v side) of the 7808's positive voltages pins. As shown on the "PDF" file that I posted.
The capacitor can also be soldered right at/on the clarifier's potentiometer (8v) pin, with the other (Negative) end of the capacitor to ground.
It can be smaller than the 1000uf/35v, but no less than 16v ..... it will filter the 8v right at the clarifier potentiometer .... another one close to the 7808 (8v output) wouldn't hurt either.
Look at the capacitor(s) as a battery constantly being charged to keep the voltage from sagging ..... 0.004v sag is a lot for a clarifier as you have noticed, must have also been the reason for the TRC-465 having the 7808 from the factory.
Those two ORANGE wires going to the 7808 need to be dressed, to keep them from shorting to ground, at the soldered points, with shrink tubing .... would make for a bad day without it. (Just my 2¢)
I've dealt with these little "TX/RX" voltage differences (for 50 years) that can only be seen with a DMM, and also being just enough to hear between two radios on the bench.
Glad I could help ...... Nice job.
Reactions: doffo
Thats a whole lot of strain on the pads if this is going to be installed mobile.
You should also check to be sure that there is no modulation appearing at the output. A DMM won't see it, those don't respond fast enough and the average it shows in TX could be deceiving.
A scope is the only way to know. You have it installed an inch from the antenna jack, and that definitely warrants checking. You would want to AC couple the scope and either auto range it or turn the volts per division down so it actually shows mV changes while you AM modulate.
edit to add: electrolytics don't shunt RF either, so if you insist on keeping it in a strong RF field like that, add 10nF caps in parallel with the electrolytics.
Appreciate the feedback. I do have a 2nd 1000uf 35v cap off the clarifier potentiometer.
I will see if I got some 10nf caps to put along the electrolytics.
It looks heavy, but the part alltogether was very light weight. The board itself held the legs good, but I dont think it would break off. (I honestly don't drive on any rough roads.) I will add some shrink tubing as well. :)
Reactions: MKwrench
I did relocate it to the back of the radio on the chassis so its now more sturdy. I did add two of the 10nf ceramic caps near each capacitor.
Radio still seems happy. :)
Thanks again!
Reactions: Cable Guy
Forum gripe. I looked at this page in a private tab (not logged in) and it seems things are being inserted into the middle of peoples posts. I can see a little advertising at the end of a post, but in the middle of it, and using their own words as links? I think trying to make something appear as if it were posted by a user is a little on the shady side. I happily pay to have no ads, and I totally understand having ads to further support the site, but it should not be happening in this manner.
The lightning symbol and the word Radio become a link. The site is literally turning peoples words into links. This is what happens when clicked.
Look, I get it, ads pay the bills, but when you turn the words of your forums users into marketing opportunities, it is a misrepresentation of that user. The person writing the post, paid member or not, did not endorse whatever product or service the link goes to. Mods/admins, please put a stop to this.
  • @ Spanish:
    Where do i upload schematics
