what is going on that causes backward swing with the amp on?
It swings forward just the radio no amp. And swing forward on a different amp
If he is putting too much drive into the amp putting several feet of coax inline is going to do nothing to solve the problem.11ft, 4 inches of RG58 (with hard, clear center insulation) will often fix the swing on the amplifier.
You can coil up the jumper to keep it out of the way
We need more information.
This doesn't address the problem of not knowing what radio, what amp, what drive power he is using.The drive impedance of the amplifier changes as the carrier is modulated.
A 4 watt carrier 100 percent modulated produces 16 watts of peak power.
Solid state amplifiers are supposed to have a resistor network on the input, to balance the drive impedance.
The solid state radio protection circuitry reduces the output power of the radio, as the SWR of the radio goes up.
This causes the reverse swing.
The coax jumper trick fools the radio protection circuit and allows it to maintain power as it is modulated.
This will usually result in forward swing of the amplifier output.
Yes, I know.This doesn't address the problem of not knowing what radio, what amp, what drive power he is using.
You can keep repeating the coax will fix it without knowing what is going on with the OP's situation but unless he answers the questions it just a guess.
