what is going on that causes backward swing with the amp on?
It swings forward just the radio no amp. And swing forward on a different amp
If he is putting too much drive into the amp putting several feet of coax inline is going to do nothing to solve the problem.11ft, 4 inches of RG58 (with hard, clear center insulation) will often fix the swing on the amplifier.
You can coil up the jumper to keep it out of the way
We need more information.
This doesn't address the problem of not knowing what radio, what amp, what drive power he is using.The drive impedance of the amplifier changes as the carrier is modulated.
A 4 watt carrier 100 percent modulated produces 16 watts of peak power.
Solid state amplifiers are supposed to have a resistor network on the input, to balance the drive impedance.
The solid state radio protection circuitry reduces the output power of the radio, as the SWR of the radio goes up.
This causes the reverse swing.
The coax jumper trick fools the radio protection circuit and allows it to maintain power as it is modulated.
This will usually result in forward swing of the amplifier output.
Yes, I know.This doesn't address the problem of not knowing what radio, what amp, what drive power he is using.
You can keep repeating the coax will fix it without knowing what is going on with the OP's situation but unless he answers the questions it just a guess.
This is why I keep a station monitor (Kenwood SM-220, Yaesu YO-101/901, Heathkit SB-614) inline....or have a service cart w/ a Tek 7603 mainframe available to roll around the shack to various spots. Can throw a spectrum analyzer plugin or vertical amp/timebase combo in and look at transmitted signals if any doubt.
Class D stuff is always run barefoot here but there are a lot of other radio/amp combos where verification of TX purity is important.
As far as amplifier input padders are concerned:
If done correctly they're always going to present a near 50 ohm load to the exciter. If done haphazardly or cheaply, on the other hand...
In an ideal design they'll do both.The input resistors are not there to reduce the drive to the amplifier, but are meant to maintain a steady impedance to the radio's output.
