Kenwood TS440S Too high voltage in VCO 5 (7.8v versus 5v)
Logic gates made of bipolar transistors are called TTL, or transistor-transistor logic. CMOS chips use mosfets instead of bipolar transistors. The C in CMOS comes from the complimentary pair in a push-pull configuration.
There are two easy ways to kill mosfets by accident. The insulation between the gate and substrate is so thin that sometimes voltage as low as 12v can punch through and destroy it. Bipolar transistors are more tolerant to voltage spikes, they just avalanche and reset themselves. If you get a nearby strike (or a cat) that can induce enough voltage in a gate trace to exceed that breakdown voltage, its toast. Static sensitive doesn't mean you need to feel or hear the zap, its often far less.
Another risk to CMOS chips is if the device is powered when there is a nearby strike. Then, the required induced voltage is just that to turn on the mosfets. In a push-pull configuration, turning them both on at the same time results in certain destruction as they pass supply current straight to ground through the complimentary pair burning them both up.
My thinking earlier that the H-field audio probe may not work on a CMOS chip was flawed because there is still the drain current pulses, not sure why I was doubting it. My brain gets a little clouded sometimes lol.
Back to the radio. I was simply thinking that maybe running down the service manual's parts list searching IC numbers would give us a quick indication which are worth looking at, but thinking about it more, its probably most of them.
Reactions: Ghetto
Hey Brandon and anyone else watching this thread :)
Thought I'd give an update. I took a break a month ago after feeling a bit flat with it. But I decided to trace all PLL board cmos IC voltages to get a feel if it was financially viable as you were saying and I decided to keep working on it as a hobby/project as most ICs had proper voltages etc and these radios seem to be holding their value online.
I replaced two more ICs yesterday, IC4 and IC9 on the PLL Board with mn6147c. The associated test points are now stable instead of being pegged out. I have not yet adjusted TP voltages. IC9 was a mn6147 but apparently you can replace with a mn6147c (some say its a newer version, some say its higher frequency version...i personally don't have a clue as you know.. :).
Today I've just confirmed receive is now running listening to ch35 (27.355) LSB. YAY!!! I can now clearly hear people making calls and radio appears to be spot on frequency. I still need to check other frequency ranges etc.
But I'm still working through it all (voltages on pins vs schematic) and I'm waiting for a SN74LS90N to arrive to replace IC3 as I think its faulty as I'm missing 3.9v from pin 14 on IC3 (I have 0.8v). Do you agree?
That's great to hear! It's awesome that you have stuck with it. Resurrecting a lightning strike radio is a heck of an achievement (well, I'm assuming that's what happened with so many bad ICs)! Hopefully there isn't too much else wrong.
That IC's sole purpose in life is to generate (well, divide down to) 455kHz, so if it outputs that, leave it alone. If not, swap it. I don't remember if that is a transmit only thing or not, so if you don't see 455kHz in RX, key up and see. Just remember to have an antenna or dummy load connected.
Check in AM
Reactions: Ghetto
Your the main reason I did stick with it, you gave me enough mentoring, motivation and insight to go for it. I can never thank you enough. Its RX does have some weird noise introduced < 500khz but everywhere else sounds fine.I have the IC on its way so I'll chuck it in. I still gotta work on why ATU is not running and if TX works etc but one step at a time :)
Should of taken your advice, if its working leave it alone!! (mantra for rest of my life now...) Replaced IC3, didnt realise IF top board had a broken hinge screws and it slid forward while testing - its metal chassis screw contacting the outside shell of electrolytic C59 on front control board peeling its plastic wrapper back making contact to metal shell. Now have low audio rx audio volume on all modes other than FM.
Its still receiving on frequency, but what a stuff up. I'm sure we've all done something like this before but damn it sucks.
Think I might try to check all voltage on IF board maybe as the plan of attack. Anyone want me fix your radio? Wheres that smiley face missing teeth.... :)
I did put the original IC3 back in but think I will check my solder work again etc.
This is fascinating to follow. I've just been lurking around. I'm not really able to grasp all this, but I'm learning a little bit. Congratulations on your progress ghetto! And thank you for being super patient Brandon! This is one of the reasons I hang around Worldwide DX.
This thread is relevant to my interests. Good on OP for keeping another 440S alive and out of the parts bin.
I have two of these. One apparently an early model and another, a later. There are differences in at least two of the boards (RF Unit and one of the Switch Units on the front chassis section) and these are NOT interchangeable.
One of the switching diodes (10M BPF) on the later unit's RF Board failed and I'm in the process of replacement of all of them. The earlier one was bought as part of a "Parts-Not Working" bundle from one of the ham radio stores and I managed to repair its damaged front panel and controls.
A couple 2.7KHz B/W Murata filters are going to replace the stock 2.4KHz parts in the TX chains of both. I also have a selection of wider SSB RX filters which will find their way into the rigs.
Both of mine are set up to run as twins with an R-5000. Also in that lineup is a PS-50 and AT-250. A custom cable integrates 440, 5000 and AT-250 - though I have to use manual bandswitching. No band data is present on any of the rear panel connectors.
Makes for a neat camper/portable/secondary shack station. I'll swap my IC-7200 in the upstairs office out at some point for the ensemble.
Reactions: Ghetto
Thanks for the encouragement. Yeah Brandon is all star in his support, above and beyond. Tech5 etc. So is anyone else that helps. As a beginner I like hearing any response! Great bunch of knowledgeable helpful people on this forum.
Thanks, how could we bin a ts440s! I think I'm stuck in the early 90's. I always wanted one back then. Thanks for the info - didnt know there was board revisions. I think the one I have is an early model, eg 1986 based on its serial number and had the brown corrosive glue (not the later model with non corrosive white glue).
I've done some reading on murata filters and shape. Stock being CFJ455K14 and apparently replacing with a CFJ455K12 or CFJ455V1 makes a difference on SSB RX/TX (circuit improvements for ts440s pdf on the net tip). I get where your going with that.
I actually want to experiement with a diy DSP for the audio, even its pc based software emulated.
You got a cool setup there with the R5000.
