Mobile Antenna ideas needed !
FlyBoy50
Radio 75
Feb 22, 2019
2,462
4,047
273
75
Well the time has come that I had to part ways with my old 2004 Ford Expedition ( Sob ) because it's getting to expensive to keep it on the road. I just purchased a 2023 Ford F 150 but the problem is the Aluminum body doesn't go well with all my Magnetic mount antennas. I have some ideas cooking as a work around but with all the experience in here I think it is time to open up my eyes and ears again to a treasure trove of experience. All my ideas involve a lot of money to be spent. The trouble with these new trucks is they don't have good side mirrors to work with but I don't have much experience there also.
HELP Please. LOL
The best way is to not be afraid and drill a hole and use a clean installation looking NMO mount with CB stud adapter. These are fine for fiberglass whips or loaded coil antennas like the Wilson 2000. If you sell the truck, there are NMO caps so not to leave an exposed hole.
If you are using a big metal coil antenna you could look at stake hole mounts but I understand many newer trucks don't have stake holes anymore.
Look at Breedlove mounts for many different mounting options. These are some of the best stainless steel mounts available. While not cheap, these are high quality and made to last.
Note: Mag mounts should only be used for temporary setups. They don't ground with the vehicle well, high power setups tend to scar the paint underneath the magnet, and in an accident, the mag mount becomes a projectile which could cause extra damage or injury and it won't be covered by insurance.
Pics of NMO mount with an OPEK CB stud adapter
Thanks for the ideas so far & looks like I'll have to do some thinking on this project. Sometimes I can be a Old Hard Head about Antenna in the center of the roof and need a kick in the pants. First thing I'm going to a truck cap place to see what is available that I can add a ladder rack to the front and back of the cap to haul a little long lumber on occasion.Then I could fabricate a bracket for a tilt type antenna mount in the front of the cap which would then put my antenna on center of the roof line. The night is young but you know what they say about the best laid plans of mice & men ! LOL
Thanks to all
I vote for punching the hole. I've punched 2 vehicles I've owned now, one I owned before and my now daily driver. I bought a greenlee 3/4 knockout punch and that made it a breeze.
The previous one was a an suv so I punched it in the very center just a tad towards the rear of the truck. The one now is a sedan and I went with the trunk lid option. I wasn't completely sold on the trunk lid optiin but the antenna works really well there too.
I use the Laird nmo-27 antenna and although it isn't a big power handling antenna it works nicely with my barefoot ssb rigs.
I don’t recommend using an NMO mount. They aren’t as strong as a 3/8"-24 mount, and with a large 11-meter antenna, the mount could be easily ripped out if it strikes something.
Reactions: FlyBoy50
Good point to think about as we travel the over grown byways.
True with large antennas and I mentioned in my post that if a large metal antenna is being considered, look at stake mounts or other options. I wouldn't put anything like that on the roof and that's why I only recommended NMO mounts for fiberglass whips which can absorb much of the shock and will flex with a strike, at least to a point before breaking.
Ideally, the Wilson 2000 with the 5 inch shaft would be a good choice for a roof mount with NMO and 3/8 x 24 adapter because the whip is thin, flexible, and unbreakable. A shorter piece of 3/8 x 24 all-thread could be used to put the Wilson coil even closer to the roof to lower the antenna overall height. Hard strikes like from tree limbs shouldn't disturb the NMO mount but yes, a direct solid low clearance hit will but then you shouldn't be that dumb to drive under something like that.
There are also NMO CB antennas made by Tram/Browning and Larsen he can consider and should work fine.
Truer word were never spoken. When ever I have a antenna on my roof I always keep aware of where I'm going. But even then once I got caught off guard on a major secondary road that is usually well kept. The wind or nature made a limb hang too low and it took my Sirio 5000 performer Mag Mount off the top of my little Cobalt and mangled the mag base and coax. It bent the stinger pretty bad but I managed to save it and the hinged coil it was hooked to, but had to replace the mag base and coax so it rides again. Mistakes get costly !
HELP Please. LOL
Here is my shameless plug.
Large coil, 1KW+ power handling, DC grounded, copper and brass coil assembly, *NMO* style mounts available (5" mag, trunk lip, roof mount etc).
PM for details.
PM for details.
What antennas are those? The coils are quite an upgrade to the small coil on my Laird nmo 27.
