SDR antenna transceiver switcher
Jolly Green
9CA203
Feb 24, 2025
27
104
FN35
Hello WDXers,
I'm running a SDR setup on RX and using a cheap PTT relay switcher box to TX with an IC-7300. It's so cheap, it's craptacular. TX bleeds through the SDR and it's fixing to eventually fry its input stage. And it starts to go bananas after a while and I have to "reset" it by unplugging it. Anybody got suggestions on something that has proper shielding and doesn't cost 500 bucks? Preamp would be nice but not necessary.
Obviously it has to work in the HF range, 100 Watts minimum.
The junk I got:
What I would REALLY like (local to me, like a twenty-minute drive, but the guy doesn't make them anymore)
1776732853942.pnghttps://www.youtube.com/watch?v=GZqQC2HlnAo
Might consider these, but no idea on its innards. Anybody try these?
Interesting but expensive. There's also a no-preamp version. Still no idea on quality but some say it has as much as 100 dB isolation.
1776732969046.pnghttps://www.dxengineering.com/parts/qro-rx-auditepre
I'm open to info and suggestions here.
Cheers, mates.
Maybe I'm missing something, but WHY would you use an SDR for a receiver when you're using an IC-7300?? Surely the 7300 is a superior receiver in every way to the SDR? Just curious..........
Here are the main reasons.
Better spectrum visualisation on a 4k screen with 10Mhz span.
Simultaneous RX with virtual VFO.
Superior noise filtering and equaliser handled by software.
So, yeah, I still have a problem to solve. :D
I haven't tried this myself, but the following is very cheap to make and looks quite promising.
edit: Forgot to say, but I would add that to your existing sdr switch - receiver chain, not just replace it with this.
I examined this and it looks sound. At first I was afraid it might induce attenuation, but it looks manageable especially at HF frequencies or by choosing lower capacitance diodes.
At any rate, I wish to fix the root problem and replace the switcher and then see if this is still necessary.
  • @ Spanish:
    Where do i upload schematics
