Does anybody happen to have a schematic for this amplifier? I searched the net and can't seem to find one. Thank you in advance.
Sure sounds like a failed filter capacitor in the negative grid-bias voltage source. Did all the small electrolytics get replaced along with the big ones? The only rational approach is to replace every, single one, large and small both.distorted and underwater
Nomad....That's why I like you. You think outside the box brother. I know something is causing oscillation in the tubes just couldn't put my finger on it. I think you nailed it cause I can honestly say that I can't see anything wrong with this. I'm going to install the shield. P.S. tune control is not twitchy at all. The amp loads and tunes fine. I will hit you back after I install the shielding bro. '73Is the driver's Plate Tune control a bit "twitchy"? Does it behave differently on one side of the knob's peak position than it does on the other side of the peak? Next suspect on the list after a grid-bias fault would be a stability issue, especially in an amplifier with a built-in driver stage. Maco amplifiers are famous for this problem. We routinely place a bit of hardware-store screen between the driver tubes and the final tubes.
Like this:
Likewise, the coax from the final-stage Load control to the antenna relay should have the shield grounded. Maco would leave the shield "floating", not connected at all. Those two "upgrades" are mandatory for any Maco that we work on,
