Scout 20 4 driving 4 amplifier
The problem is audio. Previous owner had the HV supply caps replaced 2 weeks ago. Amp loads and tunes fine with full output power. It has proper biasing and the plate choke is in good shape so there should be no feedback into the HV supply. The amp is being driven by a Cobra 148GTL, which should not overdrive this amp configuration and yes the limiters are still intact in the radio. Radio is keying 3.8 watts on AM swinging to about 7 watts...no more. Tubes are lighting up evenly. I'm suspecting something is causing tube oscillation because audio is sounding distorted and underwater. That is all the info I can offer at this time. Thanks.
Yes. All electrolytics were replaced 2 weeks ago. They are all 105c caps. If one of the filter caps in the negative grid-bias voltage source failed you would not have full output power from the amp. This has full output.
That doesn't make sense. That short would be evident as soon as you turned the amp on. If by chance it didnt blow up, it would cause the tubes to red plate from excessive current draw and you definitely would not have full power output. Thank you all for your input. I will continue on with this amplifier and report my findings once I figure it out.
  • @ Catalyst 122:
