$1000 PDL II clone
The PDL-II was designed when antenna design didn't fully understand quad and loop antennas.
Both the PDL-II and Maco V-Quad had both loops exactly the same external dimensions.
This used to be thought to be important.
Later it was found that the reflector loop could be physically larger around.
The loop spacing on the PDL -II is very close.
Maybe not bad in itself, but doesn't seem optimized.
I have seen a couple of sources claim that despite the driven loop looking like a full wave loop, its gamma match feed actually has it tuned or acting as a folded half wave element, with a quad loop reflector.
When these two antennas were designed, it was falsely thought that loop antennas didn't gain much by having more than two elements.
It has since been found that loop antennas gain as much from additional elements as Yagi antennas do.
Modern loop antennas use different size loops for the different elements.
The Maco Y-Quad (not the V-Quad) usually has a wider frequency range than the PDL-II and Maco gamma match might be slightly easier to tune.
I do like true quad loop antennas though.
Reactions: BC Coyote
Horizontal Full Wavelength Loops also make excellent Driven Elements for Yagis. Typically a bit quieter and 50ish ohm feedpoints when parasitic elements are added.
Reactions: Studebaker Hawk
Vertical full loops make good reflectors for Yagi antennas, because their angle of radiation is lower.
That's the main reason for the Moonraker type antennas.
Vertical is popular in CB and not so much in ham radio.
A horizontal dipole starts out as bidirectional, while a vertical dipole is omni-directional.
A horizontal yagi often has more gain than a vertical yagi, but a vertically polarized full wave loop is bidirectional, which makes it start out stronger as part of a directional antenna than a vertical yagi element.
Have to disagree with you on that one. There are amateurs the world over working HF with ground-mounted and elevated verticals with multi-wire ground radials under them. And a thriving market of manufactured antenna choices out there.
7 3
