There were at least two false theories about delta loop antennas in 1963.
These influenced the PDL-II and the V-quad.
One was that loop antennas didn't gain much by making them more than two elements.
The other was that both loops, driven and reflector, worked best when made the same external dimensions.
Note that three element beams have greatly increased front to back ratio, compared to two element beams.
dual loops do have slightly better front to back ratio than a two element yagi, which generally has poor front to back ratio.
This is the reason two element yogis are fairly rare for CB.
The two element loops were designed back when that was thought sufficient for loop antennas and the trouble to add another loop was thought not worth it.
So three element can make excellent front to back ratio.
More elements generally increase gain by narrowing the beam width, which isn't always desired.
