Cobra 2000 MB8719 Mod
HavaV10
219
41
58
Lake Havasu City, Arizona
Just picked up my 5th Cobra 2000. It has the factory installed MB8719 PLL installed. How easy would it be to just had some wires and a couple of SPST to get some extra frequencies? Does anyone have the procedure for this? Thanks for any info.
Pin 10 on the 2000 is isolated by default, so cutting a trace isn't required. Also, I never knew the factory to install the mb8719, rather the mb8734, so it may have been installed later, I could be wrong. Here is the "Poorman's channel conversion" I have for the 8719...
It's easy, but the channels aren't exactly in order and quite a few dupes. IMHO, if it's going to be mainly used for ssb, this is the way to go. If using mainly on AM, a xtal kit will keep the channels in order and no dupes, but the added drift and headache of keeping the xtals on point make it less desirable for ssb use, although it can work if you keep the leads short and remain diligent. That's all I got, so good luck.
