Trc458 transmits on 22.500 recieve ok
Copycat32
NNJ32
Feb 9, 2024
136
58
66
Northern New Jersey
Hi all I have TRC picked up at an estate sale.. It recieves fine am and ssb..
But on transmit it's txing at 22.500 on all 40 channels am and ssb has good output power and audio the radio was partialty recaped looks like audio and power supply.. Psu puting out 13.5 v
Any one run across this issue?
Thank you
I had an old PC122 that was someone elses basket case. The PLL wouldnt lock at the correct voltages, as an experiment I added voltage to the lock line to see if the rest of the radio worked. I remember it recieved fine, but transmitted at some lower frequency, . Then after removing the added voltage I believe the radio started working properly on transmit, with double the VCO voltage spec.
Reactions: Copycat32
Do you have a second radio you can use to see if any signal at all is coming out on the channel frequency. If that 22.5 is all that comes out you won't hear the selected channel. If you can hear that channel, alignment might be the solution.
Reactions: Ghetto
I'm gonna guess the PLL is out of lock (since all channels are the same) and the VCO is nearly railed. The drift also suggests the VCO. It kinda sorta has to be the VCO being railed because what else can be off by almost 4.5MHz and drift 50k? Nuthin else can. That 50k drift is the critical clue here.
See what the lock detect pin on the PLL has to say.
One thing that may cause that is a missing tripler signal. Check to see if the 11.285/33.855MHz signal is there.
It recieves OK on the proper channels but definitely TX on 22.500.. Am ssb on all 40. I'll have to dig in ordered a service manual I'll go through the alignment step by step.. I noticed there's one broken slug up in fron on a double can but don't think that's the cause.. I'll have to try and remove the slug and replace it. . The radio was partialty recaped the power supply set at 13.8 and the audio section recaped new recieve diodes o. And audio mod diod and cap c174 has a 2.2 50v electrolitic. That's it stock other wise.
What are you measuring with and how? Can you look at what is going onto the PLL mixer? 22.500 is roughly, the second harmonic of the carrier oscillator. If your counter range caps out at 30 MHz, you may not be seeing the third harmonic after the tripler. Look at TP6 and tune L24. I would also look at the loop filter.
