Cobra 25 stinger set up
Illahe
New Member
Jun 3, 2026
43
14
8
57
Question: Installing a 1446 stinger pallet in a Cobra 25 chassis that requires 2 w DK. I'm aware of the cap and resistor mod to lower DK. Is there another option that doesn't need heavy mic gain to open up the 4:1. Most of the time they run in the 10W region modulating sans stinger.
Back in the day we advised the drivers that you need variable only if you'll use more than one amplifier. Different amplifiers have different drive requirements. For an over-the-road combo of just one radio and just one amplifier, the resistor mod is simpler, one less knob to turn the wrong way.
Your stinger will probably require around a half Watt to keep it below 10 or 15 coming out. A former employee had a method. He kept the 1-Watt resistor values from 68 to 150 ohms handy, and would use two gator leads. The jumper wire would get cut, and one gator lead to each side of the cut. Trying one then another value resistor would zero in on the desired carrier from the linear. That value got soldered in, and the capacitor added. This is not useful advice unless you have the range of resistor values on hand to try. He got tired of this method and used a 5-Watt wirewound 250-ohm pot on the gator leads. Once the desired carrier level was set, it got unclipped and measured with the ohmmeter. The closest fixed value to that measurement would go into the radio.
Naturally he tried a pot with a smaller Watt rating at first, and it kept wearing out. I explained that if the circuit was using only one quarter of the resistance element inside the control, the Watt rating was a quarter of a Watt, not the full one-Watt rating of the control. We had a 250 ohm 5-Watt pot in our inventory, and it didn't wear out prematurely.
We found it necessary to put a .01uf disc cap to ground from the end of the cut jumper, the rear end that leads to L13, the driver collector coil. Some versions have that capacitor, some don't. If it's there, you don't need to add one.
Have fun and 73
Reactions: Illahe
Have fun and 73
I like the schematic that " Uncle Ronnie" posted as well. I get the test procedure you have outlined! saves some trial and error. I have found that the DK on "swing kit" 29's I have done will increase after I tune l14, at times going from 1w to 2.5~. Your method is duly noted.
The thread Ronnie linked also has a board with a high and low adjustment, which I find feasible. Especially if someone get happy with the mic gain.
the "more involved" method is cleaner hands down. If im going for idiot proofing, i build the carrier pot on a trimmer inside the radio for a "set and forget" kind of thing. on a 25 i've also made the ch 9 switch into a hi-low using 2 trimmers inside. theres a ton of options. my 21gtl with a biased FQP13n10 is swingin 15 RMS and 45peak with a clean waveform from a 1.5w DK.
Reactions: Illahe
Respectable performance. Is there a reason you prefer the 13n10 over say Vishay 520.
And did you use a bias potentiometer instead of the "Palomar "bias set op for Mosfet conversion.
i like 520s too, i just saw these on ebay for cheap and experimented. so apparently i got a really good batch lol. i use resistors like 470 and 3.3k with a diode, and 6.8k from the 8v tx line for biasing.
oh and BTW the RFX75 cobra 29 i just un-hacked is now keying 9w, swingin 40 RMS and 90-95ish PEP. i had to reinstall the jumper to the driver stage and make the trace cut but its mean and clean
Reactions: Illahe
Nice!
I just picked up a Connex 33 HP Max, but I don't believe its any louder than a well tuned 29 with "a little help."
