RIP Iowa
357
Walkin' the dog From Chilliwack BC
Sep 12, 2009
1,542
935
123
53
Chilliwack, BC
www.youtube.com
VIDEO
Officials recommend people who live or work in potentially affected areas take the following precautions:
  • Consider avoiding affected areas.
  • Remain indoors during the potential exposure period.
  • Keep windows, exterior doors and other openings closed.
  • Turn off heating and cooling systems or set them to recirculate, if safe to do so, to minimize outdoor air intake.
  • Avoid unnecessary travel through affected areas.
  • Wet-clean frequently touched surfaces, including playground equipment, outdoor furniture and windowsills, after the Army determines the air exposure period has ended.
  • Consider washing vehicles that were parked outside at a car wash.
The Army said children, pregnant people, older adults and other vulnerable populations should be especially cautious about outdoor activities in affected areas.
It wasn't a bomb that decayed like the video states, I believe it's barrels of azide used to make detonators and other initiating mixtures.
LA is most safely stored wet with ethanol, but over the 20 or so years its been there, some of that ethanol evaporated away. That left larger more sensitive crystals of the primary explosive. Being lead azide is nearly insoluble in the ethanol, it is not a simple task to remove or dissolve them. Depending on the exact wetting solution, it could have formed long thin needle-like crystals or thin platelets that are both very fragile and can easily detonate if broken. It is way more sensitive than the powdered form.
Wet lead azide is not going to detonate completely, so not only will it spread metallic lead, it will also spread lead azide. With azides high toxicity to aquatic life, it will be interesting to see what happens to the surrounding lakes. Thankfully, all this stuff is nearly insoluble in water because I think mathes lake drains into long creek into skunk river and into the mississippi.
Another thing worth noting is that it is in a root cellar bunker, so this need to hurry before it freezes is a little dramatic IMO. It will surely be a little while longer before the inside of that bunker gets cold enough to freeze water.
If they have time, maybe they can do some stability tests of lead azide after using different solvents that dissolve the crystals. Perhaps they can render the mess stable enough to then deal with properly.
My bet, they make it tomorrows problem and blow it regardless of how much time they really have. I think the real hurry here is that they want their base back. I bet most of it is off limits on account of the risk right now.
Reactions: 357
Not really up on the topic but didn't the court throw the breaks on the whole ordeal.
Courts ordered an indefinite moratorium on blowing it up. Army says it's going to do it anyways because the stuff is so unstable it will blow up by itself if they don't do it first. It seems the army can legally override the court order, so I'd assume they will go ahead with the planned explosion sooner rather than later.
Reactions: 357
Apparently the US military cannot over ride a US state decision .
Reactions: 357
Apparently it happened on Wednesday.
It did. It was very underwhelming!
