Transformer test fixture
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,296
2,529
293
I tore apart a few relays to use the contacts to make a couple IF can test sockets. I plan to have sma connectors to feed signals from a sig gen into one side (50 shunt amd 10k series to tank to keep sig gen matched but limit tank loading) and a jfet source follower on the secondary.
Sockets seem to work good, now to add the rest of it.
I think having to be really careful when soldering SMD stuff has made me sloppy with the big iron lol
Cool.
Did you see this toko tester?
That's cool, but I don't think it will do what I want it to. That looks like an oscillator that uses a fixed capacitor to calculate inductance based on frequency.
I want to see the bandwidth of tuned transformers (ones with built in caps) under light loading conditions. I went with 10k source resistance so the tuned primary sees about the same loading as it might in a radio's IF, so hopefully the Q I see is close to what it would be in a typical circuit. The idea is to be able to compare coils and get a general idea how they might behave.
I plan to make another set of can sockets for a direct connect version for S11 measurements. If I measure inductance at a frequency so low the internal cap disappears, I should be able to figure out the turns ratios. Just trying to make evaluating unknown ones in detail a little easier.
  • @ Hambones amps:
