Transformer test fixture
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,688
2,994
293
upnorthradio.net
I tore apart a few relays to use the contacts to make a couple IF can test sockets. I plan to have sma connectors to feed signals from a sig gen into one side (50 shunt amd 10k series to tank to keep sig gen matched but limit tank loading) and a jfet source follower on the secondary.
Sockets seem to work good, now to add the rest of it.
I think having to be really careful when soldering SMD stuff has made me sloppy with the big iron lol
Cool.
Did you see this toko tester?
That's cool, but I don't think it will do what I want it to. That looks like an oscillator that uses a fixed capacitor to calculate inductance based on frequency.
I want to see the bandwidth of tuned transformers (ones with built in caps) under light loading conditions. I went with 10k source resistance so the tuned primary sees about the same loading as it might in a radio's IF, so hopefully the Q I see is close to what it would be in a typical circuit. The idea is to be able to compare coils and get a general idea how they might behave.
I plan to make another set of can sockets for a direct connect version for S11 measurements. If I measure inductance at a frequency so low the internal cap disappears, I should be able to figure out the turns ratios. Just trying to make evaluating unknown ones in detail a little easier.
I finally put the parts on the can tester. Initial results on two cans. The little can is 455kHz, the big can is 16MHz. I have a 10dB attenuator in line, and with the transformer ratio and nothing but a jfet for a load, it the overall amplitude probably doesn't mean much. At least it gives a good idea of bandwidth for similar loading. At the very least, I now have an internal cap tester.
It really taught me something. I have heard it here before (many times) that the inductance is highest with the slug flush with the top of the can. Seeing it on the SA really made me think about that. I have often felt that turning the slug in deeper than flush still increased the inductance, but seeing it visually made it click.
I made a short video of it on my channel yesterday.
Thinking I should do a better video on this so I can intentionally sacrifice the internal cap and see how the response changes to highlight the false peak that is said to occur when the cap is bad.
I imagine with max inductance, there would be max flux and max transfer to the secondary. I think watching the difference from the perspective of a fixed IF frequency would be interesting.
I remember a test setup from decades ago that switched a fixed capacitor in parallel with the IF transformer winding. This tester was an oscillator circuit, and the change in frequency could be used to calculate the value of a transformer's internal capacitor. This is a spec you never see on a schematic. Knowing that value would permit using a fixed external cap to take the place of a failed-open internal cap. The trimmer-cap method we use works, but seems crude. The trimmer gets set at min or max just often enough to make me wish for the original cap's capacitance value.
Interesting, thanks!
I had to work out the math on that. Cinternal=Cadded/((f0/fwith added cap)^2-1).
Edit to say: this gives value to the toko tester 19wrc333 mentioned, I should have given it more attention.
Never underestimate the power of resonance.
I meant comparing the usual resonance response to a case where the internal cap is gone (no resonance), ie. the false peak which I presume would be widebanded. I've never watched the through response of an untuned transformer as its inductance is varied. I assume it would transfer the most power with the slug flush in the event the internal cap was toast. I assume I would see a horizontal line moving up and down on the SA as opposed to a peak moving left and right.
I clearly misunderstood this idea of a false peak. I cut the internal cap and checked again, and although it did have a slight maximum with the slug flush, it was WAY lower than would be useful. All that did was shift the resonant frequency from 16MHz to 68MHz.
I believe the false peak I have heard about is actually due to a drifting cap, not a completely absent cap.
Reactions: Cable Guy
What I mean by false peak is the behavior of the tuning slug. It reaches the rim of the opening and appears to exhibit a peak because turning it further reduces inductance as the slug rises above the rim. Max inductance gets you closest to resonance without reaching it. Max inductance is typically at the 'flush' position. I compare it to an air-variable cap with no hard end stop. If you spin it 360 degrees and see only one apparent peak, it's not resonance. It's the physical end of travel. Gets you closest to resonance without reaching it. With an air variable, it's easy to tell. Turn the knob 360 and see that you have two peaks. There will be two positions where the plates are meshed correctly to resonate. Called it the "twin peaks" rule back in the day. Slug-tuned coil won't behave that way, just comes closest to resonance at that flush position. Behaves like a peak mechanically, but it's not resonance.
