Where to find this cable
HomerBB
Sr. Member
I Support WorldwideDX.com!
Jan 4, 2009
4,012
2,811
273
69
Rogers, Ar
I'm wanting a RJ45 to RJ45 repeater controller cable for the QYT KT-8900D pre-made. I don't want to make one. I want to buy one. I make antennas, not rj45 cables. Surecom offers an RJ45 to 3.5mm speaker mic cable, but I want to pair two mobiles, not a mobile to HT for crossband use.
Reactions: Naysayer
I think your right... it should be pin to pin...
But, this confuses me:
  • Wire the cable according to the standard crossband repeater pinout: Pin 1 (Data In) to Pin 7 (AF Out), Pin 2 (PTT/COS) to Pin 8 (PTT/COS), and Pin 3 (Mic Ground) to Pin 5 (Mic Ground). Do not connect Pin 1 and Pin 7 directly; they are separate signal paths."
Doesn't look like pin-to-pin.
Reactions: Naysayer
  • @ Hambones amps:
